[GRASS-dev] GRASS 7: renaming of some modules
I would like to rename a set of modules as outlined in
http://grass.osgeo.org/wiki/GRASS_7_ideas_collection#rename
Raster:
* rename r.in.gdal to r.import
* rename r.out.gdal to r.export
Vector:
* rename v.in.ogr to v.import
* rename v.out.ogr to v.export
* rename v.mkgrid to v.grid
Database:
* rename db.in.ogr to db.import
Any objections (the motivation is obvious)? I would also update
gui/wxpython/gui_modules/menudata.py
to reflect the change as well as the manual pages.
On Sat, 11 Oct 2008, Markus Neteler wrote:
Raster:
Vector:
Database:
Hi Markus,
Can you elaborate on the motivation? As it is I feel an obvious objection is that this implies there is no other way to import raster and vector data than through GDAL and OGR respectively - but I count 8 r.in.*, 14 r.out.*, 4 v.in.* and 6 v.out.* modules in 7.x. So IMHO it is confusing.
Also v.mkgrid is IMHO clearer than v.grid - in the latter it is not so obvious what the module does with the grid. I guess it is consistent with the names of other vector modules though. But changing a module's name is always confusing (choice of a good initial name for a new module is thus VERY important).
Paul
On Sun, Oct 12, 2008 at 5:43 PM, Paul Kelly
Raster:
Vector:
Database:
Hi Markus,
Well, teaching GRASS over the year almost always brought up the
newcomer question: "Where [censored] is the import module?".
r.in.gdal or v.in.ogr is *not* obvious at all.
Since GDAL support 50+ formats, it's a quite good approximation.
Additionally, not (yet)part of my request, a subset of the r|v.in.* might
be retired since r.in.gdal/v.in.ogr meanwhile do the job.
Also, if r.import/v.import fail, still r.in.*/v.in.* are there as
further possibility.
Ok, for me that's not very important.
VERY important).
Yes. This was missed with r.in.gdal/v.in.ogr.
Hi Markus,
Thanks - surprisingly it wasn't actually obvious to me that the motive was newbie confusion! And yes I agree, good point - I also vaguely remember when starting GRASS being confused as to when r.in.gdal might be useful. And taken alone, r.import and r.export are very good names, easy to remember and also quick to type. I guess it's just the inconsistency that will then exist with r.in.* and r.out.* that I'm concerned about.
If r.in.gdal was renamed to something like r.in.multi or r.in.various that would be one way of preserving the consistency. Renaming r.in.* to r.import.* and r.out.* to r.export.* at the same time as renaming r.in.gdal to r.import would be another possiblity for preserving consistency. Neither of those are ideal; I'm not seriously suggesting either of them.
Is the idea of the proposal then to make new users see r.import as the standard import tool they should try first, and that r.in.* are legacy modules to look at if they have difficulty or special requirements? If so, I guess I'm generally in favour of it after all.
Paul
Hello Paul and Markus,
at some point would it be useful to get an Import Wizard up and running?
It would call the necessary r.in* or v.in* according to needed formats…
Michael and I worked on a wxWizard at some point,
maybe it could be a good time to resurrect that work?
Yann
2008/10/13 Paul Kelly <paul-grass@stjohnspoint.co.uk>
Hi Markus,
than through GDAL and OGR respectively - but I count 8 r.in., 14 r.out., 4
newcomer question: “Where [censored] is the import module?”.
r.in.gdal or v.in.ogr is not obvious at all.
Thanks - surprisingly it wasn’t actually obvious to me that the motive was newbie confusion! And yes I agree, good point - I also vaguely remember when starting GRASS being confused as to when r.in.gdal might be useful. And taken alone, r.import and r.export are very good names, easy to remember and also quick to type. I guess it’s just the inconsistency that will then exist with r.in.* and r.out.* that I’m concerned about.
If r.in.gdal was renamed to something like r.in.multi or r.in.various that would be one way of preserving the consistency. Renaming r.in.* to r.import.* and r.out.* to r.export.* at the same time as renaming r.in.gdal to r.import would be another possiblity for preserving consistency. Neither of those are ideal; I’m not seriously suggesting either of them.
Is the idea of the proposal then to make new users see r.import as the standard import tool they should try first, and that r.in.* are legacy modules to look at if they have difficulty or special requirements? If so, I guess I’m generally in favour of it after all.
Paul
grass-dev mailing list
grass-dev@lists.osgeo.org
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
