how about replacing r.los with r.viewshed?
2011/12/1 Markus Neteler <neteler@osgeo.org>:
+1
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
I'm supportive of that, starting with trunk. (too
late for 6.4.2) r.los just doesn't scale.
still one final small detail with the color rules
I'd like to see:
https://trac.osgeo.org/grass/ticket/390
It requires knowing the range of angle values once
0 and 180 have been taken out.
thanks,
Hamish
+1 from me, looking forward to using r.viewshed on some massive maps-
would be nice to have it in the standard install of GRASS.
Dylan
late for 6.4.2) r.los just doesn't scale.still one final small detail with the color rules
I'd like to see:
https://trac.osgeo.org/grass/ticket/390It requires knowing the range of angle values once
0 and 180 have been taken out.thanks,
Hamish
grass-dev mailing list
grass-dev@lists.osgeo.org
needs fixing:
grass65/dist.i686-pc-linux-gnu/include/grass/iostream/replacementHeapBlock.h:146: warning: 'str' may be used uninitialized in this function
(3 times).
Hamish
needs fixing:
(3 times).
Did you ever have a look at the compiler warnings for r.terraflow?
I have already ported r.viewshed to trunk in my local copy, I just
need to submit it...
Markus M
