[GRASS-dev] GRASS 7 scripts overhaul
I have tested almost all GRASS 7 scripts and fixed a lot of them (mostly
broken in the parser part).
To all relevant (most) I have added North Carolina examples for easier
testing.
This set of modules I did not manage to fix:
* db.in.ogr
-> it does not, as programmed, delete the empty geometry and the cat column
* d.rast.leg
-> messy output, at least in wx0
* i.in.spotvgt
-> NameError: global name 'string' is not defined
* i.landsat.rgb blue=lsat7_2002_10 green=lsat7_2002_20 red=lsat7_2002_30
Processing <lsat7_2002_30>...
Color table for raster map <lsat7_2002_30> set to 'rules'
Processing <lsat7_2002_20>...
Color table for raster map <lsat7_2002_20> set to 'rules'
Processing <lsat7_2002_10>...
Color table for raster map <lsat7_2002_10> set to 'rules'
WARNING: Unable to write history for <lsat7_2002_30>. Raster map
         <lsat7_2002_30> not found in current mapset.
WARNING: Unable to write history for <lsat7_2002_20>. Raster map
         <lsat7_2002_20> not found in current mapset.
WARNING: Unable to write history for <lsat7_2002_10>. Raster map
         <lsat7_2002_10> not found in current mapset.
* i.spectral
-> no more errors but also no output
* r.mask
-> should show '[Raster MASK present]' as in GRASS 6 in the user prompt
* r.out.xyz (trying to export to elev_lid792_1m.csv)
-> File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/scripts/r.out.xyz",
line 42, in main
    outf = file(output)
    IOError: [Errno 2] No such file or directory: 'elev_lid792_1m.csv'
* GRASS 7.0.svn (latlong_wgs84@neteler):~ > v.in.wfs
url="http://mapserver.gdf-hannover.de/cgi-bin/grassuserwfs?REQUEST=GetFeature&amp;SERVICE=WFS&amp;VERSION=1.0.0&quot;
out=grass_users
Retrieving data...
Importing data...
ERROR: Unable to open data source
       </home/neteler/grassdata/latlong_wgs84/neteler/.tmp/north/18964.0.xml>
WFS import failed
* v.out.gps -t input=railroads output=trail.gpx
[nothing happens...]
^CTraceback (most recent call last):
  File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/scripts/m.proj",
line 278, in <module>
    main()
  File "/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/scripts/v.out.gps",
line 316, in <module>
    main()
line 207, in main
    p2.stdin.write(line)
KeyboardInterrupt
The rest in now ok, at least for the test cases added to the manual pages.
red=lsat7_2002_30
'rules'
'rules'
'rules'
Raster map
mapset.
Raster map
mapset.
Raster map
mapset.
It tries to run grass.raster_history() without first testing
if the map is in the current mapset.
the shell script version has this test to avoid that trouble:
# write cmd history (only if raster maps are located in the current mapset)
CURRENT_MAPSET=`g.gisenv MAPSET`
BLUE_MAPSET=`g.findfile -n elem=cell file=$BLUE | grep mapset | cut -d'=' -f2`
if [ "$BLUE_MAPSET" = "$CURRENT_MAPSET" ] ; then
    r.support ${BLUE} history="${CMDLINE}"
fi
probably we should continue this thread in bug reports.
thanks for the testing,
Hamish
Given that those maps are listed as inputs, it's debatable whether it
should be modifying the history even if those maps are in the current
mapset.
In any case, the corresponding fix is:
--- scripts/i.landsat.rgb/i.landsat.rgb.py (revision 48120)
+++ scripts/i.landsat.rgb/i.landsat.rgb.py (working copy)
@@ -124,8 +124,10 @@
       set_colors(i, v0, v1)
     # write cmd history:
+ mapset = grass.gisenv()['MAPSET']
     for i in [red, green, blue]:
- grass.raster_history(i)
+ if grass.find_file(i)['mapset'] == mapset:
+ grass.raster_history(i)
if __name__ == "__main__":
     options, flags = grass.parser()
mapset.
All that i.landsat.rgb does is creating color rules. They are stored
in /colr2 if the input maps are not in the current mapset. As r.colors
does not modify the raster history, and i.landsat.rgb is just a
front-end for r.colors, one could argue that i.landsta.rgb should not
touch raster history as well.
my2c
Markus M
\# write cmd history:
grass-dev mailing list
grass-dev@lists.osgeo.org
Markus Neteler wrote:
testing.
* db.in.ogr
fixed
* d.rast.leg
fixed by Michael Barton
* i.in.spotvgt
fixed
* i.spectral
worksforme
line 42, in main
outf = file(output)
fixed. BTW, r.out.xyz is nothing more than r.stats -1gn
Markus M
testing.
[snip]
main()
main()
line 207, in main
KeyboardInterrupt
I think the piping from p1 to p2 is broken because the scripts tries
to sneak in between p1.stdout and p2.stdin and p2 is maybe getting
confused.
Considering that OGR supports writing out gpx or anything gpsbabel
supports, v.out.gps tries to do what v.out.ogr can already do? So why
not getting rid of v.out.gps? Removing a module for a change would be
nice;-)
Markus M
On Mon, Sep 5, 2011 at 4:11 PM, Markus Metz
nice;-)
Sounds very good to me. There also also some other leftover (?) shell
scripts there.
Still open:
On Sun, Sep 4, 2011 at 12:20 PM, Markus Neteler <neteler@osgeo.org> wrote:
* r.mask
In GRASS 6, there was lib/init/prompt.sh for this job. Currently one cannot know
from the command line if a MASK is there or not.
out=grass_users
Retrieving data...
Importing data...
WFS import failed
One more:
* when leaving GRASS 7 with d.mon wx0 still open, the polling never finishes.
gpsbabel supports, v.out.gps tries to do what v.out.ogr can
already do? So why not getting rid of v.out.gps?
v.out.ogr can certainly _not_ export to anything that gpsbabel
supports. That's the entire point of v.out.gps. GPX is the
main overlap and thus why it's used as the in-between format
in the script: the script exports as GPX with v.out.ogr internally
and then gpsbabel converts from GPX to whatever.
http://www.gpsbabel.org/capabilities.html
http://gdal.org/ogr/ogr_formats.html
In fact v.out.gps roughly doubles the number of vector formats
GRASS can export to. Being able to load up your handheld GPSs
with wpts/trks/rtes directly from the GIS is a great and useful
feature to have.
keep it.
n.b. If Glynn's python port is working well, there's no reason
to keep the old shell script version of it in trunk any more.
thanks,
Hamish
ps- note I still need to port (aka rewrite) the v.in.gpsbabel
shell script to v.in.gps (python) in trunk. v.in.garmin can be
dropped (it has richer support for older Garmin hardware).
https://trac.osgeo.org/grass/changeset/45975
> testing.
[snip]
> main()
> main()
> line 207, in main
> KeyboardInterrupt
confused.
It's m.proj which is broken:
    p = grass.Popen(cmd, stdin = grass.PIPE, stdout = grass.PIPE)
cs2cs' stdout is redirected to a pipe, but the script never reads it.
It needs:
--- scripts/m.proj/m.proj.py (revision 48154)
+++ scripts/m.proj/m.proj.py (working copy)
@@ -235,7 +235,7 @@
     # cs2cs | sed -e 's/d/:/g' -e "s/'/:/g" -e 's/"//g'
     cmd = ['cs2cs'] + copyinp + outfmt + in_proj.split() + ['+to'] + out_proj.split()
- p = grass.Popen(cmd, stdin = grass.PIPE, stdout = grass.PIPE)
+ p = grass.Popen(cmd, stdin = grass.PIPE)
     while True:
   line = inf.readline()
supports.
But see
http://gdal.org/ogr/drv_gpsbabel.html
Markus M
On Tue, Sep 6, 2011 at 7:31 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
It needs:
@@ -235,7 +235,7 @@
cmd = \[&#39;cs2cs&#39;\] \+ copyinp \+ outfmt \+ in\_proj\.split\(\) \+ \[&#39;\+to&#39;\] \+ out\_proj\.split\(\)
while True:
   line = inf\.readline\(\)
Fixe in r48160.
This leads now to:
    main()
line 260, in main
    for line in p.communicate()[0].splitlines():
AttributeError: 'NoneType' object has no attribute 'splitlines'
ERROR: Error reprojecting data
Hamish:
> gpsbabel supports.
Markus M:
But see
hmmm, a most interesting and welcome development.
none the less, wrt v.out.gps I'd still argue for a separate,
specialized, and easy to use front end (script) for interfacing
with field work GPSs. I was not sure for v.in.gps if we should
use the v.in.ogr GPX method directly or stay with the earlier
gpsbabel grass vector ascii format (grass_write_ascii.style)
definition + csv->db.in.ogr method. In the interest of strength
through diversity I'm now leaning towards the gpsbabel style-
file method. That makes reprojection to/from WGS84 slightly
easier than fun with ogr2ogr, and I'd suspect make the operation
a bit less lossy, but I suspect we'll only know the answer to the
lossiness question after trying both ways.
In the past the various v.in.garmin, v.in.gpsbabel, and
v.in.ogr(GPX)-only methods all ended with very different levels
of metadata/attribute loss, with the oldest of the 3 (v.in.garmin)
giving the least loss, in situations where the gps was an old
enough garmin for it to work.
Hamish
Fixe in r48160.
This leads now to:
line 260, in main
Oops. I was looking for references to p.stdout, and missed that. The
actual problem was calling p.wait() before reading the output.
Try r48203.
On Thu, Sep 8, 2011 at 10:26 AM, Glynn Clements
Try r48203.
Now it is back to deadlock (?)
line 274, in <module>
    main()
    main()
line 207, in main
line 245, in main
    p.stdin.write(line)
KeyboardInterrupt
KeyboardInterrupt
> Try r48203.
Try r48225.
On Sat, Sep 10, 2011 at 12:32 AM, Glynn Clements
Try r48225.
Now a different one:
GRASS 7.0.svn (nc_spm_08@neteler):~ > v.out.gps -t input=railroads
output=trail.gpx
line 287, in <module>
    main()
line 267, in main
    y, z = yz.split(' ')
ValueError: too many values to unpack
> Try r48225.
line 267, in main
I've improved m.proj as much as I can.
The main problem is that, when cs2cs is run with the -E flag, it
appears to copy the input semi-verbatim, meaning that the output
format varies according to the input format. This makes it impossible
to reliably parse the output from cs2cs.
On Mon, Sep 12, 2011 at 8:24 PM, Glynn Clements
> Try r48225.
line 267, in main
Thanks for your efforts!
Still...
line 288, in <module>
    main()
line 267, in main
    x, y = xy.split('\t')
ValueError: need more than 1 value to unpack
I believe that cs2cs should get the equivalent to the -g flag in GRASS which
makes the output truely machine-readable.
Perhaps we concentrate on more important issues than v.out.gps and
let it rest for now. Thanks, Glynn, I am sure that m.proj is way better now.
On Mon, Sep 5, 2011 at 9:57 PM, Markus Neteler <neteler@osgeo.org> wrote:
Still open:
* r.mask
This has been kindly fixed by Martin now.
out=grass_users
Retrieving data...
Importing data...
WFS import failed
Yet open (but not important for me).
One more:
d.mon will need some more work to make is especially faster. Perhaps
stream compression could be used? But I didn't study the internals (yet).
Perhaps stream compression could be used? But I didn't study
re. 'd.mon wx0' also it would be wonderful if you could turn off
the top menu bar* and the bottom status line to get 100% map real
estate. Functionality of those icons could go into a right-click
context menu with tick-mark menu entries to display them or not.
Just looking at how xfce4-terminal does it, besides their
Show _Menubar
menu item there's a
_Fullscreen
menu item too. ooh, lets one of those too please. :slight_smile:
[*] I could rip the menu bar off into a floating window, but not
close it without taking down the rest of the window with it.
thanks a bunch,
Hamish
