... as the subject says, I suggest to
# grass7:
svn rm vector/v.digit/
svn rm visualization/nviz/
svn rm lib/gtcltk/
Makes sense?
Is there already a replacement for
lib/form/
# grass7:
svn rm lib/gtcltk/
Makes sense?
lib/form/
Is lib/form used also somewhere else except v.digit?
Maris.
The Tcl/Tk version of v.digit doesn't use lib/form; it has a local
copy.
lib/form is used by v.what and nviz. In 7.0, v.what only uses it to
generate plain text (format = F_TXT, edit_mode = F_VIEW), so the
dependency could be removed without much effort.
# grass7:
svn rm lib/gtcltk/Makes sense?
Is the wxPython version of NVIZ sufficiently complete?
Is there already a replacement for lib/form/
I'll remove the lib/form dependency from v.what.
2008/11/15 Glynn Clements <glynn@gclements.plus.com>:
# grass7:
makes sense for me
Not yet, but I am planning to work on it.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
