cd swig/python/
make
gcc -I/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include -g
-Wall -fno-common -mtune=nocona -m64 -minline-all-stringops -fPIC
-I/usr/include/python2.5 -I/usr/include/python2.5
-DPACKAGE=\""grasslibs"\"
-I/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include -o
OBJ.x86_64-unknown-linux-gnu/utils_wrap.o -c utils_wrap.c
utils_wrap.c: In function 'pyseq_to_ptr':
utils_wrap.c:2564: warning: format '%d' expects type 'int', but
argument 3 has type 'Py_ssize_t'
/usr/bin/swig -I/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include
-python -module date -shadow date.i
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/datetime.h:18:
Warning(314): 'from' is a python keyword, renaming to '_from'
OBJ.x86_64-unknown-linux-gnu/date_wrap.o -c date_wrap.c
date_wrap.c: In function 'pyseq_to_ptr':
date_wrap.c:2563: warning: format '%d' expects type 'int', but
-python -module grass -shadow grass.i
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:39:
Warning(451): Setting a const char * variable may leak memory.
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:587:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:591:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:593:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:594:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:595:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:596:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:604:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:607:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:608:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:617:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:618:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:619:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:625:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:626:
/home/neteler/grass70/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:627:
OBJ.x86_64-unknown-linux-gnu/grass_wrap.o -c grass_wrap.c
grass_wrap.c: In function 'pyseq_to_ptr':
grass_wrap.c:2620: warning: format '%d' expects type 'int', but
grass_wrap.c: In function '_wrap_G_vasprintf':
grass_wrap.c:18166: error: incompatible types in assignment
make[1]: *** [OBJ.x86_64-unknown-linux-gnu/grass_wrap.o] Error 1
make[1]: Leaving directory `/home/neteler/grass70/swig/python'
make: *** [default] Error 2
Looking around grass_wrap.c:2620
static void *pyseq_to_ptr(PyObject *input, int data_type)
size_t size;
Py_ssize_t len;
len = PySequence_Length(input);
array = malloc(len * size);
fprintf(stderr, "sequence length is %d\n", len);
swig -version
SWIG Version 1.3.36
Linux mandrivalinux.local 2.6.27.7-server-1mnb #1 SMP Thu Dec 11
17:41:52 EST 2008 x86_64Intel(R) Core(TM)2 CPU T5500 @
1.66GHz GNU/Linux
cat /etc/issue
Mandriva Linux release 2009.0 (Official) for x86_64
Kernel 2.6.27.7-server-1mnb on a Dual-processor x86_64 / \l
>> I get warnings and errors in swig/python/:
> No idea what's causing this. For me, line 18166 is:
> arg3 = *((va_list *)(argp3));
> with arg3 defined as:
> va_list arg3 ;
> The others are just warnings.
I have
if (!argp3) {
SWIG_exception_fail(SWIG_ValueError, "invalid null reference "
"in method '" "G_vasprintf" "', argument " "3"" of type '"
"va_list""'");
} else {
On Mon, Jan 19, 2009 at 12:37 PM, Glynn Clements
> va_list arg3 ;
I have
if (!argp3) {
"va_list""'");
} else {
> What does the declaration of arg3 look like?
va_list arg3 ; <<<----
So assigning an expression of type va_list to a variable of type
va_list results in an "incompatible types in assignment" error from
the compiler?
I can only suggest taking this up with the gcc maintainers; I have no
clue.
On Mon, Jan 19, 2009 at 5:19 PM, Glynn Clements
the compiler?
clue.
> the compiler?
> clue.
On Tue, Jan 20, 2009 at 11:53 AM, Glynn Clements
> the compiler?
> clue.
