[GRASS-dev] GRASS 7 - Ubuntu package build problem on Launchpad
I did small investigation why Ubuntu package of GRASS 7 is failing to build on Launchpad.
The problem is caused by building single page documentation (make htmldocs-single). This make command is also failing on my computer. Building multi-page documentation (make htmldocs) is running without problem.
I am not able to figure out the problem with ‘single-page’ build, since I do not use Doxygen at all.
So the question is if somebody is able to fix ‘htmldocs-single’ or it is possible at least temporary substitute ‘htmldocs-single’ to ‘htmldocs’ to allow building the package.
Ivan Minčík
ivan.mincik@gmail.com GPG: 0x79529A1E http://imincik.github.io/0x79529A1E.key
ivan.mincik@gista.sk GPG: 0xD714B02C http://imincik.github.io/0xD714B02C.key
Hi Ivan,
2014-12-08 7:16 GMT+01:00 Ivan Minčík <ivan.mincik@gmail.com>:
on Launchpad.
first of all, thanks for you time.
These commands build API documentation [1]. I guess it's not needed
for debian packaging, right? The user documentation [2] is build via
default make command. I wonder there is attempt to build API manual
for debian package. It doesn't make sense to me so much.
Martin
[1] http://grass.osgeo.org/programming7/
[2] http://grass.osgeo.org/grass70/manuals/
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
please tell us what exactly is failing. Thanks, Martin
Martin Landa
2014-12-08 10:01 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
or it should be part of `grass-dev` package? Martin
Martin Landa
On Mon, Dec 8, 2014 at 10:01 AM, Martin Landa <landa.martin@gmail.com>
wrote:
Hi Ivan,
build
> on Launchpad.
Building
The same docs was build also in GRASS 6 packaging. It is a content of
'grass-dev-doc' package.
Removing it means loosing this package.
It is failing with meaningless error [1]:
*** [htmldocs-single] Error 2
The same error I get even if running by hand with 'make -d'
1 -
https://launchpadlibrarian.net/191285764/buildlog_ubuntu-precise-i386.grass70_7.0.0~ppa~2~revno-31311~ubuntu12.04.1_FAILEDTOBUILD.txt.gz
Ivan Minčík
2014-12-08 10:12 GMT+01:00 Ivan Minčík <ivan.mincik@gmail.com>:
OK, than it make sense to me.
also with `make -j1` ? Thanks, Martin
Martin Landa
2014-12-08 10:15 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
from attached log:
make[2]: Entering directory `/build/buildd/grass70-7.0.0~ppa~2~revno/lib'
make[2]: *** No rule to make target `htmldox-single'. Stop.
I will take a look at it. Martin
Martin Landa
Hi Ivan,
2014-12-08 10:26 GMT+01:00 Ivan Minčík <ivan.mincik@gmail.com>:
The same unusable error message with make -j1:
HTML reference in directory ./html/index.html
make[1]: Leaving directory `/home/pkg-grass'
for dir in lib gui/wxpython ; do \
          make -C $dir htmldox-single ; \
        done
make[1]: Entering directory `/home/pkg-grass/lib'
make[1]: *** No rule to make target `htmldox-single'. Stop.
make[1]: Leaving directory `/home/pkg-grass/lib'
make[1]: Entering directory `/home/pkg-grass/gui/wxpython'
make[1]: Leaving directory `/home/pkg-grass/gui/wxpython'
make: *** [htmldocs-single] Error 2
should be fixed in r63433. Please could you try to compile trunk?
After some testing I will backport it to relbr70. Thanks, Martin
Martin Landa
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 08.12.2014 10:57, Martin Landa wrote:
Hi Ivan,
2014-12-08 10:26 GMT+01:00 Ivan Minèík <ivan.mincik@gmail.com>:
HTML reference in directory ./html/index.html make[1]: Leaving
directory `/home/pkg-grass' for dir in lib gui/wxpython ; do \
make -C $dir htmldox-single ; \ done make[1]: Entering directory
`/home/pkg-grass/lib' make[1]: *** No rule to make target
`htmldox-single'. Stop. make[1]: Leaving directory
`/home/pkg-grass/lib' make[1]: Entering directory
`/home/pkg-grass/gui/wxpython' make[1]: *** No rule to make
target `htmldox-single'. Stop. make[1]: Leaving directory
`/home/pkg-grass/gui/wxpython' make: *** [htmldocs-single] Error
2
Currently I have no time to try it in latest trunk, but I have applied
your fix in to the version I am testing (which is latest failed
version from Launchpad - grass70_7.0.0~ppa~2~revno-31311) and it seems OK.
Ivan Minèík
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJUhX6XAAoJEPfdLsR5UpoeGj0H/0KwPNt6/2F14P4GS9Sv6MP3
+FwLK7mz9/T9JfsExwTSER39dSKLaK9fW1vm104Cs0Nb691qiJpdDh7OfScL/D/w
vVUQTpp0U/UAJGQ12z0JDiPZV0WDWw05YIEug63HtRCma6L++RGxno0j9ZNeaWi/
RfAm97iR8XFcuGC2YrPWLAECeW+8l3uGpAro3N8r82Dolu3b5OyBz8xyg09E9Ov8
JIvWb6q0YjYXoo0Yc+royr3tApUyGCJBFsuv0eSAnUxNOMcJFgtVngAG0RVcGU4r
5Wg+JtZxkACpX40RW1YVSRsO+J1q8fCSmm+gmw4r7iPMmNJ7xXIFg5pifYU/t0Q=
=Pdu8
-----END PGP SIGNATURE-----
Hi Ivan,
2014-12-08 11:34 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
OK, I have backport it to relbr70 in r63434.
BTW, revno-31311 means really r31311 [1], than it's bogus (7 years ago commit).
Thanks for your time, Martin
[1] http://trac.osgeo.org/grass/changeset/31311
Martin Landa
Hash: SHA1
ago commit).
Martin, sorry for confusing you. 31311 is bazaar import revision
number [1].
1 -https://code.launchpad.net/grass
Ivan Min?ík
Version: GnuPG v1
iQEcBAEBAgAGBQJUhYGsAAoJEPfdLsR5UpoeNjsH/27nyey73hq8mVkuyTiUQpDu
xg3KnC2+okSVOhFyosau9lKPyPaWLdXGLSaOu0pxwuFzm00klAyZ+DcUIk2aVAw9
44KT4h1XFKnizEM0AYtEbReHrI6il26ijHRLEtpsvq5k3mICc5qAb0ab5ronJuk0
iD4eNMyXDDMqSeGJ4trvEonCbxU8wOqk0ESiIzNMlMBBOZX2pE1E65ZYZrr0X+1X
od76InfGlr6LFC5+q/RY+AewJTYomLM05Yp9IK6Ohoilz76KqUJsxhgcaAeIkyK4
44MV357o4g2hUq+rMgJn3MG0G1FzmQnoKQel1iXsELesREgyZ1ILytXBnjlycA4=
=yjxL
Hash: SHA1
I am waiting for Launchpad tu upload latest SVN version which is still
waiting for something [1] and than try to build new package.
1 - https://code.launchpad.net/~grass/grass/releasebranch_7_0
Ivan Min?ík
Version: GnuPG v1
iQEcBAEBAgAGBQJUhb15AAoJEPfdLsR5UpoeN88H/jVgtxgMaih8UWzRpybfs5Dv
RBzFzU4Q8sk+PCXwJAhQDBWzidY8UY20I5fVDEyLzxdx0edpQDI/p9IUioHhayoX
5g0BJxrLjb2e2/iMuXE/G2RbwclAAf6uMbKnsoCjzEuIWR226eDoETwsnHlKk3qL
pNOX84HX9F3njcIgCuaeN8YJajLTsiHhjZrHZK3Nguzz0li3viXU9C9SeFnPDyJf
+QpB3/8J3GMVhrdQsDCaeTcoiUINOAKLXwBXVSCdfQVcLT2eWFQu0U0hO9dos1Xd
16BhwYqWtCsg1cgJUOmtIioeZ32jcJBjWY0QqZspGreqDRqZvgFqpb7/VAYaHJ8=
=Dmcr
2014-12-08 11:47 GMT+01:00 Ivan Mincik <ivan.mincik@gmail.com>:
ago commit).
number [1].
thanks for explanation :slight_smile: Martin
Martin Landa
Hash: SHA1
I confirm that GRASS 7 is now building successfully in my PPA [1].
Somebody from GRASS team should request for build in GRASS PPA.
1 - https://launchpad.net/~imincik/+archive/ubuntu/gis-dev/+packages
Ivan Minčík
Version: GnuPG v1
iQEcBAEBAgAGBQJUhhPlAAoJEPfdLsR5UpoesFMIALlY9uvnkJXoZ0LaqWVd0raU
/NGzUkJVA7bzILnmBAkGfdSCqKxhrztSBTSEM/A89WBoE4UIZJeUuyZHY45AXM+s
psAAkC04jV4oy8xgodKGSpl9+wis1mImRDnIuZHBWnQIwpadh+aJEIW8dliUIpjU
ReXrc2ZaHe27kfytnjxnh1YJ/dV/zMKyURaj7iEDhSC6t8Ycm+pmk1pseAmYrgHY
J13ydatYhIEffn+LX5iaqSdXy8PrsnU2r93uJUtInv1ADgZfg4PTjhRraPTnOFY5
OyAo5u3yTgiJNoPPBH2mWoUE3vpDJYXayA3mceZruIdZvMKFCIhe6n7w3eytMko=
=oxe3
Hash: SHA1
Excellent, thanks for your efforts!
If still needed: I have a login there, what should I do? Sorry for
being without PPA experience...
But it seems to be done:
https://code.launchpad.net/~grass/+recipe/grass70-release
Ivan Minčík
Version: GnuPG v1
=oxe3
grass-dev mailing list
grass-dev@lists.osgeo.org
Hash: SHA1
wrote: I confirm that GRASS 7 is now building successfully in my PPA [1].
If still needed: I have a login there, what should I do? Sorry for being
No, what you see on that page is actually build in my repository (GIS packages
(development) is mine).
You have to do it also for yours. Click on 'Request build(s)' and build it for
your stable repo.
Ivan Minčík
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJUiWJ7AAoJEPfdLsR5UpoeVtIH/ihhtKf9ZP/THwcrwA9OD4Xd
5K71ChXBAsb3ztjiGyiLvB90jOUFCvLPKw66pdiZLRs94KFUnUp8yPOKebvSEj6h
JPFqgeKWZxcbNiWgjAttNyj38tfFq9WGmn2dHPSSxGIBfIjwhvKHgXdUa3OLxpdY
W7+vEnP+7AIvcfvKKQU6j/dtthlNytTSci3FJAhFp3IOlWG42AO+3lJ15oB8Fz+o
wSqnGYzJ/z7fdfSRuteHUros6rdPsuJTa/4lDrMV6rXWL7pP2yNni0FEohjFzJJP
ncsTDp010H2m72LUFRpn8rhwWWXFfJN5O4AHcOTsqArs6DZHH7lgaL96u2cfgHA=
=VHL1
your stable repo.
Ok, I finally found the button:
"Request builds for grass70-release
Distribution series:
Vivid
Utopic
Trusty
Precise
Lucid
(Vivid and Lucid were not enabled by default, I would enable)
Makes sense?
Hash: SHA1
<ivan.mincik@gmail.com> wrote: ...
(GIS packages (development) is mine).
build it for your stable repo.
"Request builds for grass70-release Distribution series: Vivid
Utopic Trusty Precise Lucid "
I am not sure with Lucid. Maybe there are no suitable dependent
packages in UbuntuGIS.
Ivan Minčík
Version: GnuPG v1
iQEcBAEBAgAGBQJUiaMAAAoJEPfdLsR5UpoePnIIAI/n4vbs4R9hiQnydIuDZTrd
A0Pomlwt1wUoX8LgiNMcnorUqBY1EjlIgVJyau17nFiizca8PCMwZtCY2YNB1hwN
ZEVg4dG29dG/z659BJpMs/cqvWo8fcS2DbzOTMmMbdkvz3vv5jcBlCltmpQI4bx2
LbrKdhJuZyXYB7Rif6NT3nJfDrg+vIpswrgfcMEY/gGPKfTeYVEYpZEuOp4bV0yw
KX2rphgQslR9llboiz/+x+JpBhWJEdXQKBjEcImeKDvb2M8SbU+yf15PUmdVj6UI
7ixN3SoSiRw0o6YWsHm4lqOoubuAJJV+Osa7z4zeDGPtFoEn89GpJFvfrzb3c4w=
=JkW5
Hash: SHA1
OK, so I have taken that out. But...
"There were also some errors:
You must specify the archive to build into."
Only, there is no archive to select from (selection list is empty).
Any hints?
Ivan Minčík
Version: GnuPG v1
=JkW5
Hash: SHA1
repository (GIS packages (development) is mine).
build(s)' and build it for your stable repo.
Vivid Utopic Trusty Precise Lucid "
enable)
empty). Any hints?
In my case I have possibility to choose from my PPA archives. So it
seems that it have something to do with permissions and ownership.
According this [1], you are not a active member of GRASS GIS team :).
I am CCing Angelos. Angelos, would you please request a build of GRASS
7 for GRASS-stable repository. Thanks
1 - https://launchpad.net/~grass/+members#active
Ivan Minčík
Version: GnuPG v1
iQEcBAEBAgAGBQJUibrNAAoJEPfdLsR5UpoeIFIH/2dF7xYMhHYDbLXoJFdq+Pzn
3KYLaRl361/8yKpRi6GE2UXpqkc5pKaPHqDN6xqKCpzJDhotPyaSn+mErGQB5mjH
95Mo4WMSF63jh/U/kiisGu+/bwKrM+hpkshKNiyaqhsWINydxNCSvvpCIsAN1Qw2
Dg8TsgPffD2BeRJaBasKPT6kpKjF/PphiK/wybpaKn5SYL7gAfEFtS+Hh9g6Tdl+
IoO8+BAENEJz/IQxdfR+RucO9Yr8zQPuyUCtvk5CSdV4KEV8gYOpBUeLcS8vrb0U
bF9/TWv1tfXKm35uDAmcEqc7Wld7yb5Ktx+LLiLAyfh6K8RNQ4czzBc+lcCOuAg=
=1PsW
