trying out v.net.path on yesterday's GRASS 7 OSGeo4W, the command runs
through properly (correct result) but raises then an error:
echo 1 1 2 | v.net.path KAnet_HbfHs alayer=1 nlayer=2 out=shortpath_dist --o
WARNING: Il vettoriale <shortpath_dist> è già presente e sarà sovrascritto
Creando il grafico...
Registrando archi...
Flattening the graph...
Il grafico è stata creato
Si sta ricreando la topologia per il vettore <shortpath_dist@KA_net>...
Registrando primitive...
1 primitive registrate
140 vertici registrati
Costruendo aree...
0 aree create
0 isole create
Isole allegate...
Centroidi allegati...
Numero di nodi: 2
Numero di primitive:1
Numero di punti:0
Numero di linee:1
Numero di confini:0
Numero di centroidi:0
Numero di aree:0
Numero di isole:0
(Thu May 23 17:47:18 2013) Command finished (0 sec)
File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\gui\wxpython
\core\gconsole.py", line 647, in OnCmdDone
task = GUI(show=None).ParseCommand(event.cmd)
\gui_core\forms.py", line 2188, in ParseCommand
blackList = _blackList)
File "C:\OSGeo4W\apps\grass\grass-7.0.svn\etc\python\grass
\script\task.py", line 487, in parse_interface
tree = etree.fromstring(get_interface_description(name))
File
"C:\OSGeo4W\apps\Python27\lib\xml\etree\ElementTree.py",
line 1300, in XML
parser.feed(text)
File
line 1642, in feed
self._raiseerror(v)
File
line 1506, in _raiseerror
raise err
xml.etree.ElementTree
ParseError
syntax error: line 1, column 0
Citing a related older wish:
On Wed, Jan 25, 2012 at 3:58 AM, Glynn Clements
<glynn@gclements.plus.com> wrote:
ParseError
no element found: line 1, column 0Would someone mind fixing the code to generate a more meaningful error
message when --interface-description fails (e.g. when the resulting
string is empty or consists solely of whitespace)?
I wonder where the error comes from... happens on Linux as well. Perhaps
the pipe | is causing it?
