hi devs,
taken from the GRASS-stats ML:
https://lists.osgeo.org/pipermail/grass-stats/2016-January/001634.html
"However, it will not work for initGRASS(), which does not set
GRASS_ADDON_BASE or GRASS_ADDON_PATH.
Where should I look to see where the correct values are stored on Unix
(Linux and OSX?) and Windows? I see: GRASS_ADDON_BASE as GNU/Linux is
$HOME/.grass7/addons, on MS Windows $APPDATA\GRASS7\addons in:
https://grass.osgeo.org/grass70/manuals/variables.html
Is %APPDATA% a predictable location on Windows?
What happens if the user sets prefix= in g.extension?
On Windows, adding GRASS_ADDON_BASE\bin to the PATH is sufficient (because
all scripts in /scripts have a matching *.bat in /bin. On Unix, we need
both /scripts (for Python scripts) and /bin for compiled extensions. Do we
need toolboxes?"
maybe some hints for this?!
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-ADDON-BASE-or-GRASS-ADDON-PATH-and-other-variables-tp5244931.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
