Greetings all
you made sure to put it before the exec, right?
Yes. Now grass64 file is like this:
trap “echo ‘User break!’ ; exit” 2 3 9 15
Set the GISBASE variable
GISBASE=/usr/local/grass-6.4.0svn
export GISBASE
export GRASS_ADDON_PATH=/usr/local/myproj
exec “$GISBASE/etc/Init.sh” “$@”
I get an error window stating:
Execution failed: ‘i.ndvi’
Details:
Error:
An at command output I get:
ERROR: Required parameter not set:
(raster input map (Near Infrared)).
(raster input map (Red)).
(raster output NDVI map).
Description:
NDVI Calculation
Keywords:
raster, imagery, vegetation
Usage:
i.ndvi bandnir=string bandred=string ndvi=string [–overwrite] [–verbose] [–quiet]
Flags:
–o Allow output files to overwrite existing files
–v Verbose module output
–q Quiet module output
Parameters:
bandnir raster input map (Near Infrared)
bandred raster input map (Red)
ndvi raster output NDVI map
ERROR: Required parameter not set: (raster input map (Near Infrared)).
ERROR: Required parameter not set: (raster input map (Red)).
ERROR: Required parameter not set: (raster output NDVI map).
Description:
NDVI Calculation
Keywords:
Usage:
Flags:
Parameters:
But If I put this function at grasssvn6.4.0/scripts folder it works just fine, I mean it opens the form to enter input/ouput/options information. So it works as expected but if I put back in my addon_path folder I get these error
Any idea of what is going wrong?
Thank you
Kim
