Some addons depend on other addons. E.g. r.lfp depends on r.stream.distance.
If you try to use it while r.stream.distance is not installed, you get the following traceback which is not particularly helpful; especially so if you are not familiar with Python.
File “/home/grassuser/.grass7/addons/scripts/r.lfp”, line 111, in
sys.exit(main())
File “/home/grassuser/.grass7/addons/scripts/r.lfp”, line 43, in main
calculate_lfp(input, output, coords)
File “/home/grassuser/.grass7/addons/scripts/r.lfp”, line 67, in calculate_lfp
distance=flds)
File “/usr/lib/grass70/etc/python/grass/script/core.py”, line 392, in run_command
ps = start_command(*args, **kwargs)
File “/usr/lib/grass70/etc/python/grass/script/core.py”, line 361, in start_command
return Popen(args, **popts)
File “/usr/lib/grass70/etc/python/grass/script/core.py”, line 64, in init
subprocess.Popen.init(self, args, **kwargs)
File “/usr/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/usr/lib/python2.7/subprocess.py”, line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
So my question is whether there is a way to define addon dependencies, and if there is not, what would be a sensible way to support something like this.
r.stream.distance.
you
File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 111, in
<module>
sys.exit(main())
File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 43, in main
File "/home/grassuser/.grass7/addons/scripts/r.lfp", line 67, in
calculate_lfp
distance=flds)
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 392, in
run_command
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 361, in
start_command
File "/usr/lib/grass70/etc/python/grass/script/core.py", line 64, in
__init__
subprocess.Popen.__init__(self, args, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
this.
On Thu, Feb 4, 2016 at 11:53 PM, Martin Landa <landa.martin@gmail.com>
wrote:
2016-02-04 22:28 GMT+01:00 Panagiotis Mavrogiorgos <pmav99@gmail.com>:
and
> this.
currently it's not possible. Please fill the ticket. Martin
