when installing addons using `g.extension` you will be facing warning message:
Updating addons metadata file...
WARNING: Unable to parse
'http://grass.osgeo.org/addons/grass7/modules.xml’: no element found:
line 1, column 0
WARNING: No addons metadata available. Addons metadata file not updated.
We know about it. The building server (geo102) is down. I hope that
the server will be running soon. Martin
-----Original Message-----
From: grass-dev [mailto:grass-dev-bounces@lists.osgeo.org] On Behalf Of Martin Landa
Sent: 17. februar 2016 12:18
To: GRASS users list <grass-user@lists.osgeo.org>; GRASS developers list <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] grass addons metadata temporary not available
2016-02-16 16:46 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
Thanks for your reply. I shall try that.
I just reinstalled GRASS 7.1, but maybe I have to reinstall from a clean source and remove the existing GRASS settings / addons.
I shall report back...
Stefan
Sent: 17. februar 2016 13:39
To: Blumentrath, Stefan <Stefan.Blumentrath@nina.no>; Matej Krejci <matejkrejci@gmail.com>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
2016-02-17 13:33 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
