[GRASS-dev] GRASS and C++
I just read on the development Wiki that there is limited support for C++ and was hoping someone could clarify that. If I’m writing a module can I use C++?
Chris
Create a cool, new character for your Windows Live™ Messenger. Check it out
C++ and was hoping someone could clarify that. If I'm writing a module
can I use C++?
You're welcome to try. The main issue is that most of the configure
checks are performed using the C compiler, and any Makefile variables
are set appropriately for the C compiler.
If your C and C++ compilers are gcc and g++, you'll probably be okay,
as both understand most of the same options and interpret them the
same. If you try to use unrelated compilers, the C++ compiler may not
like being passed options which were intended for the C compiler.
can I use C++?
Also note that there is no default rule to build C++ files into .o files
so you need to add (not so sure about the implicit %.o: %.cpp rule
though...)
%.o: %.cpp
        $(CXX) -c $(CXXFLAGS) $< -o $@
CMD_OBJS = $(subst .cpp,.o,$(wildcard *.cpp))
Before you include include $(MODULE_TOPDIR)/include/Make/Module.make
--Wolf
Wolf Bergenheim (wolf+grass@bergenheim.net)
>> can I use C++?
Yes there is; see Rules.make (6.x) or Compile.make (7.0).
