[GRASS-dev] GRASS and vagrant
recently I have added Vagrantfile [1] to trunk which enables you
easily create a new virtual machine using vagrant, and compile/install
GRASS on that machine. Detailed description is available on wiki [2].
Enjoy! Martin
[1] https://trac.osgeo.org/grass/browser/grass/trunk/Vagrantfile
[2] https://grasswiki.osgeo.org/wiki/Vagrant
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Martin Landa <landa.martin@gmail.com> writes:
Enjoy! Martin
Thanks - this sounds very interesting. If my googling gave the right
answers, one can use Vagrant together with docker, which would make the
resulting instance much more lightweight than a full blown VM (e.g
Virtual Box).
Has anyone tried this?
Rainer
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
On 16 February 2016 at 12:24, Martin Landa <landa.martin@gmail.com> wrote:
Hi Martin,
thanks a lot for this submission, can I ask you why did you comment out liblas?
Enjoy! Martin
ciao
Luca
http://www.lucadelu.org
2016-02-16 14:01 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
enabled in r67850. Ma
Martin Landa
Rainer,
afaik it does not make sense to combine vagrant and docker - there are here for different use cases
http://stackoverflow.com/questions/16647069/should-i-use-vagrant-or-docker-for-creating-an-isolated-environment
@martin good work btw
J
út 16. 2. 2016 v 12:39 odesílatel Rainer M Krug <Rainer@krugs.de> napsal:
Enjoy! Martin
Virtual Box).
Rainer
Rainer M. Krug
email: Rainerkrugsde
PGP: 0x0F52F982
grass-dev mailing list
grass-dev@lists.osgeo.org
