[GRASS-dev] grass behavior: pixel value from a different resolution
Hello,
could somebody tell me how GRASS chooses a value when your g.region
settings make you operate at a pixel size larger than the original
data.
i.e. I am working in 250m res but my SRTM original data is 90m.
How GRASS will choose/calculate the value to use?
corollary:
how to export with r.out.gdal an identical map as the one GRASS would
use at 250m.
thank you,
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
Opportunities are usually disguised as hard work,
so most people don't recognize them.
