code I item #301, was opened at 20/02/2007 09:07
Status: Open
Priority: 3
Submitted By: Aldo Clerici (clerici)
Assigned to: Nobody (None)
Summary: v.report output
Issue type: module bug
Issue status: None
GRASS version: 6.2.1
GRASS component: None
Operating system: None
Operating system version: linux
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
the v.report output seems wrongly tabulated. For example:
v.report roads op=length un=k
gives
cat|label|length
0|no data|1|47.1069051508698
1|interstate|2|28.4609513530158
2|primary highway, hard surface|3|29.0730640515405
3|secondary highway, hard surface|4|151.211909391895
4|light-duty road, improved surface|5|136.313999118462
5|unimproved road|
Furhermore
v.report streams op=length un=k
gives
cat|label|length
|-1|2.42608071449311
|1|32.6145522076325
|2|183.15729968834
|3|3.45883045471837
|421|0
What are -1 and 421?
Same results for 6.2 and 6.3.
Regards
Aldo Clerici
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=301&group_id=21
