[GRASS-dev] [grass-code I][318] r.in.wms pretends to be MSIE5.5. Sod that!
code I item #318, was opened at 2007-03-01 19:50
Status: Open
Priority: 3
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: r.in.wms pretends to be MSIE5.5. Sod that!
Issue type: module bad feature
Issue status: None
GRASS version: CVS HEAD
GRASS component: raster
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
The wgetoptions= option in r.in.wms (and wms.download) adds:
  --user-agent=MSIE5.5
It doesn't help the cause any to pretend that alternatives to MSIE don't exist. I don't mind a mention in the help page to add that trick if the user comes across a brain-dead server which won't let them in, but by default we should be proud to use wget & FOSS!
I think we should remove that from the scripts.
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=318&group_id=21
