[GRASS-dev] [grass-code I][353] g.mlist through gis.m in GRASS6.2 and 6.3
code I item #353, was opened at 03/04/2007 10:35
Status: Open
Priority: 3
Submitted By: Aldo Clerici (clerici)
Assigned to: Nobody (None)
Summary: g.mlist through gis.m in GRASS6.2 and 6.3
Issue type: other bad feature
Issue status: None
GRASS version: 6.2.1
GRASS component: gis.m
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070310
Initial Comment:
In the g.mlist panel (File -> Manage maps and volumes -> List maps using expressions and 'wildcards') is written "map name search pattern, must be 'quoted'. (default:all):"
Actually the option works only if the string is not quoted.
A.Clerici
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=353&group_id=21
IOW: option descriptions should not assume that the module is being
run from a shell.
Fixed in CVS.
