code I item #354, was opened at 2007-04-03 19:29
Status: Open
Priority: 3
Submitted By: Maximilian Krambach (vagabund)
Assigned to: Nobody (None)
Summary: v.digit freeze after "Display attributes" --> "New feature"
Issue type: module bug
Issue status: None
GRASS version: 6.2.1
GRASS component: tcl/tk GUI
Operating system: Linux
Operating system version: ubuntu edgy
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
In v.digit, the following combination causes the v.digit gui (and the monitor v.digit is working with) to freeze.
1. display attribute of some feature
[...some work...]
2. new feature --> entering new label; submitting
3. display attribute of another feature
4. new feature --> creating it
the two windows freeze the moment the "label" form pops up
The monitor then is unaccessible by grass, the vector map's topology is damaged afterwards, but can be restored with v.build; the last entered new feature is added to the map.
When exiting grass via "exit", the two windows remain, but they can be closed when exiting grass by killing the terminal grass has been started with.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=354&group_id=21
