code I item #363, was opened at 07/04/2007 10:10
Status: Open
Priority: 3
Submitted By: Aldo Clerici (clerici)
Assigned to: Nobody (None)
Summary: Overwrite in r.patch
Issue type: module bad feature
Issue status: None
GRASS version: 6.2
GRASS component: raster
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070407
Initial Comment:
The option Overwrite in the r.patch panel seems ineffective. The name of the resultant map is overwritten anyway
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=363&group_id=21
