code I item #366, was opened at 2007-04-09 09:08
Status: Open
Priority: 3
Submitted By: Francesco Lovergine (frankie)
Assigned to: Nobody (None)
Summary: branch 6.2 should build grass62
Issue type: other bug
Issue status: None
GRASS version: 6.2
GRASS component: build
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
It still builds grass63 instead. IMHO after branching it should build the grass62 binary, which is much more coherent and prevents possible build failures for packagers.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=366&group_id=21
