[GRASS-dev] [grass-code I][377] d.vect map disp=dir now broken: G_plot_icon() bug?
code I item #377, was opened at 2007-04-21 22:05
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: d.vect map disp=dir now broken: G_plot_icon() bug?
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
Since a few days the "disp=dir" no longer works.
I recall to have seen some G_plot_icon() modifications. Could this
be related? The positioning is right but the symbol invisible:
#spearfish
d.vect roads
d.vect roads disp=dir
-> directional arrow no more visible
This functionality is important for graph related work such as LRS or vector network analysis.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=377&group_id=21
Status: Open
Priority: 3
Issue status: None
Initial Comment:
It could be related. I ended up multiplying by the scale twice, so if
the scale factor is significantly less than unity, the icons could end
up invisible.
Try changing lines 29-30 of lib/gis/icon.c to:
  x[i] = m[0][0] * x[i] + m[0][1] * y[i] + xc;
  y[i] = m[1][0] * x[i] + m[1][1] * y[i] + yc;
I'll commit this when CVS comes back to life.
> Status: Open
> Priority: 3
> Issue status: None
> Initial Comment:
up invisible.
I have tried but it doesn't seem to help.
Does it work for you now?
> up invisible.
That was only half of the problem; this deals with the other half:
Index: icon.c
RCS file: /grassrepository/grass6/lib/gis/icon.c,v
retrieving revision 1.8
diff -u -r1.8 icon.c
--- icon.c 21 Apr 2007 20:37:46 -0000 1.8
+++ icon.c 21 Apr 2007 21:24:44 -0000
@@ -28,8 +28,11 @@
     for ( i = 0; i < n_points; i++)
- x[i] = m[0][0] * x[i] + m[0][1] * y[i] + xc;
- y[i] = m[1][0] * x[i] + m[1][1] * y[i] + yc;
+ double xi = x[i];
+ double yi = y[i];
+ x[i] = m[0][0] * xi + m[0][1] * yi + xc;
+ y[i] = m[1][0] * xi + m[1][1] * yi + yc;
I have tested this and it appears to work now.
Committed to CVS.
> > up invisible.
Index: icon.c
@@ -28,8 +28,11 @@
+ double xi = x[i];
+ double yi = y[i];
Committed to CVS.
Very nice. Also works for me.
