code I item #389, was opened at 2007-05-02 16:51
Status: Open
Priority: 3
Submitted By: Etsushi Kato (ekato)
Assigned to: Nobody (None)
Summary: problem with r.what at the longitudinal edge
Issue type: module bug
Issue status: None
GRASS version: 6.2.1
GRASS component: raster
Operating system: Linux
Operating system version: Fedora Core 6
GRASS CVS checkout date, if applies (YYMMDD): 070414
Initial Comment:
I get null '*' value when specifying longitude edge with grass6.2.2cvs (20070414) compiled with Fedora Core 6.
r.what input=mod12 east_north=180W,55N
** note ** 180W 55N is outside your current window
180W|55N||*
If I change r.what/main.c as in the attached file, I get
180W|55N||0
I assume this is related to Fedora Core 6's compiler bug or optimization thing. However, I think it is safe to cast the dcol to int in this case.
Here is my system information.
$ cat /proc/version
Linux version 2.6.20-1.2933.fc6 (brewbuilder@hs20-bc2-4.build.redhat.com) (gcc version 4.1.1 20070105 (Red Hat 4.1.1-51)) #1 SMP Mon Mar 19 11:38:26 EDT 2007
$ gcc -v
Using built-in specs.
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --enable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=i386-redhat-linux
Thread model: posix
$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 4
model name : Intel(R) Pentium(R) 4 CPU 3.40GHz
stepping : 1
cpu MHz : 3391.747
cache size : 1024 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 3
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx constant_tsc pni monitor ds_cpl cid xtpr
bogomips : 6787.36
clflush size : 64
processor : 1
cpu family : 15
model : 4
stepping : 1
cpu MHz : 3391.747
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 3
wp : yes
bogomips : 6782.97
clflush size : 64
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=389&group_id=21
