[GRASS-dev] [grass-code I][396] Line width in v.digit
code I item #396, was opened at 09/05/2007 14:18
Status: Open
Priority: 3
Submitted By: Aldo Clerici (clerici)
Assigned to: Nobody (None)
Summary: Line width in v.digit
Issue type: module bad feature
Issue status: None
GRASS version: 6.2
GRASS component: None
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070407
Initial Comment:
In the Setting panel of v.digit the 'Line width' option seems inactive (and the lines in the monitor have a default width greater -and unpleasant- than in the previous version of v.digit).
Greetings
A.Clerici
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=396&group_id=21
I confirm this bug in 6.2.2 CVS - 'Line width' field is empty at a
start and entering a number followed by Enter key does not affect the
width of lines displayed.
In 6.3 CVS it's OK.
Maciek
Oh, pressing the 'Redraw' button renders lines according to the
declared width. I guess that previously this was not necessary; it was
enough to type in the width and press Enter, then the monitor was
re-rendered automatically. Or wasn't it?
Maciek
(just cc'd my msg; see the bug report for more)
I'm pretty sure you always had to hit Refresh in the old version.
(just tested with 6.2.1, yes, you need to refresh)
I have just fixed it in 6.3 so that the line width changes as
you adjust the spinbox. (it redraws when you change it)
I am glad to see the width reduced -- note that it needed to
be changed in global.h as well.
The "x" icon is still a bit thick.
(cleaning complicated vectors is often like picking needles out of
haystacks so any extra clutter is to be avoided, and why invalid
features are drawn on top of/after valid green ones)
n.b. the smallest D_line_width is 0, not 1. width=1 still looks
a little lumpy. (experiment with d.vect)
I tried to fix this, by changing SpinBox -range in settings.tcl
to {0 50 1} ({min max stepsize}) and this in driver.c:
void driver_line_width(int w)
- width = w ? w : 1;
+ width = w >= 0 ? w : 1;
but no luck. Is the Tcl canvas destined to be not-as-nice as
the xmon displays? (ugly stagger effect seen on thin diagonal lines)
If the tcl width has a minimum size of 1, while the xdriver had a min
size of 0, maybe this is why the line appears to be 1 size bigger than
it did before.
Hamish
