[GRASS-dev] [grass-code I][405] r.out.gdal sets NoData wrong
code I item #405, was opened at 2007-05-23 00:27
Status: Open
Priority: 4
Submitted By: Maciej Sieczka (msieczka)
Assigned to: Nobody (None)
Summary: r.out.gdal sets NoData wrong
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: raster
Operating system: all
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD): 070523
Initial Comment:
r.out.gdal sets NoData wrong. Example, in spearfish60:
$ r.mapcalc 'check=rand(0,256)'
$ r.info -rt check
min=0
max=255
datatype=CELL
$ r.out.gdal check out=check.tif type=Byte
$ r.in.gdal in=check.tif out=check_re
$ r.info -rt check_re
min=0
max=254
datatype=CELL
As you can see rasters "check" and "check_re" have different max values (255 vs 254) while those should be identical. The problem source is that r.out.gdal set 255 to null in "check.tif" by force:
$ gdalinfo -mm check.tif | grep 'NoData\|Min'
    Computed Min/Max=0.000,254.000
  NoData Value=255
As there is no null in original "check" raster, the above should rather read:
    Computed Min/Max=0.000,255.000
and no "NoData".
Note that r.out.gdal.sh is buggy too (or actually the gdal_translate, which it calls), though in a different way:
$ r.out.gdal.sh check out=check.tif type=Byte
  NoData Value=256
There should be no NoData, as there is no null in the input GRASS raster. Value 256 is not present in input "check" at all. Moreover, 256 is beyond GDAL's "Byte" value range.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=405&group_id=21
[cc g-dev]
need to set
  GDALSetRasterNoDataValue(GDALRasterBandH hBand, double dfValue)
http://www.gdal.org/gdal_8h.html#763e876f9b4c3f2b4bae2816af572fd2
"To clear the nodata value, just set it with an "out of range" value."
  NoData Value=256
The needed gdal_translate option is
       -a_nodata value:
           Assign a specified nodata value to output bands.
Hamish
Hamish Bowman wrote:
need to set
dfValue)
range" value."
Do you mean r.out.gdal needs to do it, or the user?
This is propably what gdal_translate (r.out.gdal.sh) does:
input is 0-255, type=Byte -> NoData=256:
$ r.info -rt check
min=0
max=255
datatype=CELL
  NoData Value=256
But, this is dirty anyway. I had no null in my input, so why should I
value range.
I saw GeoTIFFs without the NoData set, so should be possible in
general. But maybe GRASS raster -> GeoTIFF must have some NoData set
for some reason, ?. An issue in GDAL or GRASS?
      -a_nodata value:
What would that help? I don't want NoData in the gdal_transalate
(r.out.gdal.sh) output at all, as there is no null in the input GRASS
raster.
Maciek
