[GRASS-dev] [grass-code I][420] v.transform pointsfile does not accept points in dd:mm:ss format
code I item #420, was opened at 2007-06-07 15:12
Status: Open
Priority: 3
Submitted By: Harri Kiiskinen (harrikoo)
Assigned to: Nobody (None)
Summary: v.transform pointsfile does not accept points in dd:mm:ss format
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: vector
Operating system: Linux
Operating system version: Debian 4.0
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
v.transform does not accept point coordinated given as dd:mm:ss.ss in the 'pointsfile' option. If the coordinates are changed into decimal, everything works ok.
Harri K.
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=420&group_id=21
probably it is very easy to fix this.
The module needs to call G_scan_northing() and G_scan_easting() which
will convert a coordinate string to a double. Also there is
G_scan_resolution() for scanning non-hemispheral degrees.
It looks like they should go in v.transform/get_coor.c
use for x,y,zshift command line options as well?
Hamish
>=21
Hamish
Out of curiosity, do the methods in v.transform accurately work with spherical
coordinates?
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
coordinates?
No. v.transform performs an affine transformation, which doesn't
really make much sense for spherical coordinates.
> coordinates?
Ok- thanks for the affirmation- I was thinking the same thing. Would
it then be a good idea to include a warning as such?
dylan
