code I item #448, was opened at 2007-07-26 08:31
Status: Open
Priority: 3
Submitted By: Otto Dassau (dassau)
Assigned to: Nobody (None)
Summary: i.taget missing in tcltk tool georeferencing
Issue type: None
Issue status: None
GRASS version: 6.2
GRASS component: tcl/tk GUI
Operating system: Linux
Operating system version: debian testing
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
the tcltk menue "GRASS georectifier" in GRASS 6.2.2 needs a button for i.taget to define the target location. Currently it includes:
1) choose mapset
2) create/edit group
3) select group
4) select map
5) georectify
error message is:
child process exited abnormally
while executing
"exec -- i.rectify -ca group=muell extension=6856 order=1 >& /dev/null"
("eval" body line 1)
invoked from within
"eval [list exec -- $cmd] $args >& $devnull"
(procedure "run" line 12)
invoked from within
"run i.rectify -ca group=muell extension=6856 order=1"
invoked from within
"eval run $cmd $args"
(procedure "runcmd" line 6)
invoked from within
"runcmd $cmd"
(procedure "GRMap::rectify" line 54)
invoked from within
"GRMap::rectify"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .gcpwin.mf.topf.tb0.bbox1.b3"
(command bound to event)
defining it manually works of course
i.target -c group=muell
regards,
Otto
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=448&group_id=21
This has been resolved but I didn't see any information posted back to the
dev list.
To clarify, with the new TclTk georectifying tool, you start out in the
'target' region and georectify INTO it. Hence, you don't need to specify a
target region.
Michael
On 7/26/07 1:31 AM, "grass-codei@wald.intevation.org"
Status: Open
Priority: 3
Issue type: None
Issue status: None
GRASS version: 6.2
Initial Comment:
1) choose mapset
3) select group
4) select map
5) georectify
error message is:
while executing
invoked from within
invoked from within
invoked from within
invoked from within
"runcmd $cmd"
invoked from within
"GRMap::rectify"
invoked from within
"uplevel \#0 $cmd"
invoked from within
regards,
Otto
Wald: Exiting with error
Director of Graduate Studies
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
