code I item #449, was opened at 2007-07-26 09:03
Status: Open
Priority: 3
Submitted By: Otto Dassau (dassau)
Assigned to: Nobody (None)
Summary: r.in.gdal - output test for parameter location= fails
Issue type: module bug
Issue status: None
GRASS version: 6.2
GRASS component: raster
Operating system: Linux
Operating system version: debian testing
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
when I try create a new location using r.in.gdal with the parameter location=, there is a test for an existing map in the current mapset and the import fails.
GRASS 6.2.2 (location_utm):~ > r.in.gdal in=karte.jpg out=karte location=karte_xy
Error: option <output>: <karte> exists
-> of course there is no map "karte" in the not even existing location: karte_xy.
BTW: For v.in.ogr it works correctly.
regards,
Otto
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=449&group_id=21
