[GRASS-dev] [grass-code I][451] "place with mouse" gets confused when placing several different layers
Moritz,
Could you try with clicking inside the coordinate box of the layer desired
before trying to place with a mouse? Also, I've had luck with deselecting
and reselecting the place with mouse check box for a layer.
This is kind a hack, since you can't really place these items interactively
with the current setup (but you can with wxgrass). What is going on is that
clicking with a mouse will pick up screen coordinates, which are then passed
back to the coordinate field for the layer in question. If the desired layer
is not active the coordinates will end up in the wrong box or it won't be
able to find the box it is supposed to put them in. There may be other
causes that make the coordinates end up in the wrong layer too.
Unfortunately, the TclTk error is not more informative than the above
summary.
Michael
On 8/1/07 4:21 AM, "grass-dev@grass.itc.it" <grass-dev@grass.itc.it> wrote:
code I item #451, was opened at 2007-08-01 13:21
Status: Open
Priority: 3
Submitted By: Moritz Lennert (moritz)
Assigned to: Nobody (None)
Summary: "place with mouse" gets confused when placing several different
layers
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: tcl/tk GUI
Operating system: Linux
Operating system version: Debian Etch
GRASS CVS checkout date, if applies (YYMMDD): 070801
Initial Comment:
The "place with mouse" option in the tcl/tk GUI seems to get confused when
placing several different types of layers.
1) Place a text with the mouse, then place a ps-text with the mouse. If you
then select the text-layer again and replace it with the mouse, it disappears.
2) Place a ps-text with the mouse, then place a text with the mouse. If you
then select the ps-text layer againg and replace it with the mouse, it will
appear at the wrong place.
3) Place a text, then place a scalebar. When you select the text again and try
to place it, the following error appears. The same (or very similar) happens
with different combinations of scalebar and text or ps-text.
invalid command name ".mainframe.frame.pw1.f1.frame.sw.sf.frame.fr.at2.b"
    while executing
"$pctentry delete 0 end"
    invoked from within
"if { $pctentry != "" } {
$pctentry insert 0 "$xpct,$ypct"
# object placement marker
$mapdisp create line 167 [expr ..."
    (command bound to event)
Moritz
You can respond by visiting:
Wald: Exiting with error
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
On 03/08/07 03:10, Michael Barton wrote:
Moritz,
Doesn't change anything.
This works.
But the desired layer _is_ active, i.e. highlighted in yellow.
There may be other
It sounds more like the variable which determines which layer to attribute the coordinates to is not reinitialised when you select a layer. It only is when you uncheck+check the "place with mouse" box.
In view of the upcoming wxgrass gui, and unless identifying the culprit in the tcl/tk gui is not too difficult, knowing that unchecking+checking solves the problem is probably enough for me for now (maybe we should add a hint somewhere).
Moritz
