[GRASS-dev] [grass-code I][470] i.atcorr: hardcoded input/output map names
BTW, the links to 6s manuals in i.attcor man page are 404 not found.
Maciek
Yes, this is certainly my (late) Univ website...
Originals are still available with me to whom wants to have/host.
Maciek
grass-dev mailing list
grass-dev@grass.itc.it
Yann Chemin
http://airdensity.hi5.com/
Sainte-Anne d'Auray, France
Also, there are contrary statements about the units of 'ialt' elevation
raster:
"Input altitude map in m"
and few lines further:
"The elevation values should be in km."
Maciek
Also, please explain if/how the elevation and visibility rasters (ialt
and ivis) interefere with the target elevation and visibility
parameters in the icnd configuration file. For example, if I use ialt
raster, do I still have to/must not provide the target elevation in the
config file?
Maciek
And propably the last thing - there are 8 parameters to define in the
i.attcor config file, while "6S CODE PARAMETER CHOICES" section
mentions only 6 (A-F). How do I understand it?
Maciek
Hello Maciej,
This is the testdata config file for 6S on GRASS.
Yann
raster:
Maciek
Yann Chemin
(attachments)
ETM4_atmospheric_input_GRASS.txt (562 Bytes)
Hi Maciek,
i.atcorr is in fact the translation from F to C of 6S model.
Down there are info about it.
6s download sites (have manuals and GUI too):
http://www-loa.univ-lille1.fr/Msixs/msixs_gb.html
http://www.ltid.inpe.br/dsr/mauro/6s/
http://modis-sr.ltdri.org/6S_code/index.html
article:
http://ieeexplore.ieee.org/iel1/36/12630/00581987.pdf?tp=&isnumber=12630&arnumber=581987&type=ref
Enjoy,
Yann
config file?
Maciek
Yann Chemin
Hello again,
Altitude (DEM) input in GRASS module is in meters
Internally 6S ingests altitude data in Km, check line 274 of main.cpp
Yann
raster:
Maciek
Yann Chemin
article:
Yann,
Thanks for the reply but I don't see how it answers this particular
question, quoted below. The question is GRASS's i.attcor specific. 6s
manuals don't cover it:
config file?
Maciek
raster:
I mean that the i.attcor manual gives contrary descriptions of what
units the elevation raster should be.
Maciek
elevation raster:
Ok, I'll fix the manual accordingly.
Maciek
Hi Maciek:
Line 221-222 in main.cpp:
ialt_fd: height map file descriptor, negative if global value is used
ivis_fd: visibility map file descriptor, negative if global value is used
Yann
config file?
Maciek
Yann Chemin
Hello again Maciek,
You are referring to the config file (as example below from help file):
1) -> 8 (Landsat ETM+ geometrical conditions)
2) -> 2 19 13.00 -47.410 -20.234 (month,day,hh.ddd,long.,lat.) (hh.ddd=the
decimal hour in universal time)
3) -> 1 (tropical atmospheric mode)
4) -> 1 (continental aerosols model)
5) -> 15 (visibility in km (aerosol model
concentration)
6) -> -.600 (target at 600 m above sea level)
7) -> -1000 (sensor on board of satellite)
8) -> 64 (fourth band of ETM+ Landsat 7)
As far as I can see, the documentation deal with:
A) Geometrical conditions (ref. to #1)
B) Atmospheric model (ref. to #3)
C) Aerosols model (ref. to #4)
D) Aerosol model concentration (ref. to #5)
E) Target altitude sensor platform (ref. to #6)
F) Sensor band (ref. to #8)
Missing detailed descriptions are for:
#2) This is Sensor overpass details (in image header generally)
#7) This is less known to me since it is specifying the type of sensor, in
this case (as all of my work) it is a satellite platform holding the sensor.
I guess there is another value for airborne sensors, and this can be found in
the 6S manual.
Yann
Maciek
Yann Chemin
Yann wrote:
Hi Maciek:
used ivis_fd: visibility map file descriptor, negative if global
value is used
Yann,
Thanks. I don't know C. I'm no programmer. Can you please say which one
- the raster or the value in the i.attcor config file takes precedence?
What happens if both are specified?
Maciek
concentration)
the 6S manual.
Thanks. I'm slowly understanding how this all works and I've been
updating/fixing the manual step by step for the last past hours. I'm
going to commit it after sorting out few remaining things:
1. The example parameters file you quote says that ".-600" in line 6
means "target at 600 m ASL". However, in the i.attcor documentation,
section E of "6S CODE PARAMETER CHOICES" says: "xps <=0. means the
target is at the sea level". This is contrary. Can you please explain?
2. Section E - I'm not sure if the "-100< xpp <0" shouldn't actually be
"-1000< xpp <0". ?
3. What is the "iaer" that section D refers to?
4. BTW section D - what "Aerosol model concentration" is supposed to
mean? As it is now, it means, other words, "a concentration of the
aerosol model", which doesn't make sense IMHO. What should I change it to?
Maciek
If using a global value in the configuration file, then it is overiding the
corresponding input map.
I have not yet found a clear explaination on what to do in the config file to
read the map directly. Careful though, since reading input maps will run 6s
for each pixel (0.5-1s/pixel can be a long time for a Landsat image to
process).
Using global values from config file will run 6s once and apply an affine
transform on all the image. Fast and OK for a small area.
trade-off...
On Thursday 30 August 2007 02:49:13 Maciej Sieczka wrote:
Yann wrote:
> Hi Maciek:
> value is used
Yann,
Maciek
Yann Chemin
