[GRASS-dev] [grass-code I][478] tcl/tk gui startup screen launches grass even when 'Exit' is pushed
Hi
Ma-ris Narti¹s has submitted a patch into GForge [1]. I'm copying his
message below. Please somebody review and submit.
Date: 2007-09-20 08:54
Sender: Ma-ris Narti¹s
There was wrong use of "eval" in startup script (init.sh).
I fixed it and also changed startup screen return code to 2 for
clean exit from GRASS.
Somebody with enough karma please commit attached patch to CVS.
[1]http://wald.intevation.org/tracker/?func=detail&atid=204&aid=478&group_id=21
On 20/09/07 11:25, Maciej Sieczka wrote:
Hi
Just tested and it seems to work. Committed.
Thanks Maris !
Moritz
Hello all
(sorry for delayed response on this; been travelling a lot and only have time to "dip in" to mailing list discussions at the minute...)
Hi
Ma-ris Narti?s has submitted a patch into GForge [1]. I'm copying his
I think it's a good idea to change the behaviour here, but I feel the patch doesn't really address the problem: rather it adds more code to work around it. In particular, clicking exit in the gis_set.tcl Window won't work with init.bat (Windows) now, as it used the exit code of 1 to indicate exit (whereas the patch makes an exit code of 2 now indicate exit). I notice also the patch makes the exit code of the Python version of gis_set.tcl be interpreted differently - has anybody checked what effect this will have?
The problem is the historical behaviour that an error in gis_set.tcl (e.g. the wrong version of Tcl/Tk) caused it to drop out from attempting the GUI startup but go ahead and start an interactive GRASS shell. When I made a few changes to the return codes from gis_set.tcl I deliberately avoided tackling this because I wasn't sure what was the best solution. But on thinking about it more, I think dropping to an interactive shell is the wrong approach. It should print a warning/error message and then exit, and if the user wants to start in text-based mode instead they can use the -text switch next time round.
init.bat assumes a return code of 1 means exit. I vaguely intended the same interpretation for Init.sh, and to remove the facility to drop to an interactive shell when there was an error in gis_set.tcl, but I didn't implement this nor tell anybody about my plans: my fault :wink:
I think it would simplify things if we made Init.sh always exit when a non-zero exit code is returned from gis_set.tcl- any other thoughts? (I should probably update init.bat too so it goes ahead when 0 is returned, rather than exiting when 1 is returned).
Paul
Hi, some comments inline.
2007/9/24, Paul Kelly <paul-grass@stjohnspoint.co.uk>:
Hello all
around it.
Hm. 6 lines isn't a lot and those lines fix probelm instead of
working-a-round it.
Before this patch GUI exit code was not used at all due wrong use of
eval. It should not affect Python version at all, but I can not test
it as still there is no Gentoo ebuild for recent wx* stuff.
About init.bat You are right - it needs to be fixed. Please, fix this in CVS.
Exit code "2" isn't mandatory, it just can NOT be 0 (success - launch
GRASS) or 1 (error - use some failback or other things for error
handling).
This is debatable question - what's better - provide failback
mechanism or just give error message. IMHO better is to use some
failback, as most errors are trapped within gis_set and exit code 1
should mean some serious error.
User exit is not an error. As GRASS is hybrid GUI/CLI system, there
should be some clear exit code for user's canceled action instead of
error.
As I wrote - user exit is not an error. If You think, that GRASS
should not use text mode as failback - that's OK, but still there
should be as minimum 3 cases - no error (start GRASS); error (print
error and exit or use text mode) and user exit (just exit GRASS).
Paul
Thanks for Your input,
Maris.
What about:
returns 0: indicates location and mapset set successfully, init script goes on to launch GRASS.
returns 1: indicates user exit, init script exits and returns a value of 0 to the system.
returns any other value: indicates an error, init script exits and returns the value captured to the system (this allows future expansion of the error handling in the GUI gis_set without any changes to either init script).
I guess my only real objection to the patch was that the number 2 seemed like an obscure value to choose for the specific (and common) condition that a user had clicked exit, and that the python version and any future versions of gis_set.tcl would presumably (I haven't checked) need to be modified to return 2 on this condition.
Another option (to make it even clearer that the user clicking exit was a special case and not a "normal" error) could be that that resulted in a return value of -1, and any positive return value indicated an error, but I have no idea how cross-platform/GUI scripting language-compatible that would be.
Paul
Hi Paul,
thanks for Your efforts to standartize exit codes. I agree, that exit
code 2 probably was not best choice.
I looked on [1] and also [2] and I'm not sure that using -1 as exit
code is a good idea. Probably 130 is better choice (Script terminated
by Control-C) - as it's a USERS choice to stop programs execution.
If nobody disagrees (say now or keep mouth shut ;), could You, please,
make necessary changes in gis_set, init.sh/bat?
Maris.
1. http://tldp.org/LDP/abs/html/exitcodes.html
2. /usr/include/sysexits.h
would be.
Exit codes are limited to 8 bits, so if you return -1, the caller will
see 255.
