[GRASS-dev] [grass-code I][508] r.colors: last 100% rule is forgotten
grass-dev@grass.itc.it wrote:
code I item #508, was opened at 2007-10-10 19:37
Status: Open
Priority: 3
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: r.colors: last 100% rule is forgotten
Issue type: module bug
Issue status: None
GRASS version: 6.2
GRASS component: raster
Operating system: Linux
Operating system version: debian/etch
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
as reported on the mailing list:
  http://article.gmane.org/gmane.comp.gis.grass.devel/22645
There seems to be a bug in r.colors in 6.2 and 6.3.
e.g. for a CELL map containing values of [0-255], if the rules file looks
like this:
0% 0:0:0 37.5% 255:0:0
37.5% 255:0:0 75% 255:255:0
75% 255:255:0 100% 255:255:255
Why do you think that format should be accepted? AFAICT, nothing in
the r.colors documentation indicates that it should be, nor, AFAICT,
has it ever been this way.
FWIW, everything after the colour is discarded, so the above is
treated exactly the same as:
  0% 0:0:0
  37.5% 255:0:0
  75% 255:255:0
the usual way to give percentage is typically 1 rule per line,
No, the *correct* way to give rules (percentage or absolute) to
r.colors is 1 rule per line. It's not a matter of what's "typical" or
"usual".
I daresay that I can tweak G_parse_color_rule() to return an error if
a line has trailing garbage, rather than simply discarding it.
> Initial Comment:
> looks like this:
  0% 0:0:0
  37.5% 255:0:0
  75% 255:255:0
oops I was mixing up the final colr/ file format with the rules= input
format. My GMT color rules importing r.cpt2grass script is now updated
and working fine.
thanks,
Hamish
