[GRASS-dev] [grass-code I][565] i.smap fails because it can't find subgroup (?)
code I item #565, was opened at 2007-12-15 02:10
Submitted By: Nikos Alexandris (nikosa)
Summary: i.smap fails because it can't find subgroup (?)
GRASS version: CVS HEAD
Operating system version: Ubuntu 7.10
Initial Comment:
[I have already posted a question in the user-list about that...]
I do following in GRASS6.2.3 (from Ubuntu repositories):
> i.smap group=Change_PCA subgroup=Change_PCAsub
signaturefile=Training_iSMAPsig blocksize=128 output=TESTGRASS623
Processing rows 1-128 (of 1087), cols=1-128 (of 963)
Processing rows 1-128 (of 1087), cols=129-256 (of 963)
Processing rows 1-128 (of 1087), cols=257-384 (of 963)
Writing [TESTGRASS6.2.3] ...
100%
[Raster MASK present]
Using the same data in GRASS6.3.cvs (fresh updated, compiled,
installed) I get:
> i.smap group=Change_PCA@nik subgroup=Change_PCAsub@nik
signaturefile=Training_iSMAPsig blocksize=128 output=TEST_GRASS63cvs
ERROR: Subgroup [Change_PCAsub@nik] not found.
Where could be the error?
try the 6.3cvs command line version without the @mapset part. I think
some of the imagery libraries do not strip that off or deal with
@othermapset very cleanly. Some attempts have been made to fix those,
apparently there is still some work to do?
<aside>
the GRASS 6.3 tcl GUI always appends the @mapset to the map name, even
for the current mapset. Personally I don't like that- I think it's ugly
noise. It does that to clarify to the user which map will be used from
the g.mapsets search path if the map name exists in multiple mapsets. I
would be happy to just document/recode so that the current mapset is
always searched first, PERMANENT second, and all others after (alpha?
filesystem order?).
</aside>
Hamish
      ____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
