It's in manage:
http://trac.osgeo.org/grass/browser/grass/trunk/general/manage/cmd
Moritz
Thanks for the pointer. Is it still a bug, though? Can anyone confirm?
~ Eric.
On 21/12/07 16:01, Patton, Eric wrote:
It's in manage:
Moritz
Yup. It's due to line 28 in /general/manage/lib/do_rename.c (line
if (G_strcasecmp (old,new) == 0) return 1;
If you comment this out and recompile the lib and the command, it works. No idea why this is there. Unless someone objects, I'll remove that line.
Moritz
It's in manage:
Moritz
Actually it is due to:
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/general/manage/lib/do_rename.c.diff?r1=1.6&r2=1.7
where strcmp was replaced with G_strcasecmp, thus making the compare case independent. So, the line should not be removed, but it should either be reverted to strcmp, or we need G_strcmp, which doesn't exist at this stage AFAICT.
Moritz
Just curious, what's the point in having wrappers for two POSIX
functions like them?
Francesco P. Lovergine
>>> It's in manage:
>>> Moritz
The case insensitivity may have been intentional. What happens if you
try this with vector maps or under windows?
I suspect that G_strcasecmp() was originally added because GRASS ran
on systems which pre-dated the addition of strcasecmp() to POSIX. It
needs to remain, as Windows doesn't have strcasecmp().
There wouldn't be any point in having a G_strcmp() function.
It's in manage:
Moritz
Seems to work alright. Why should it be different from raster maps ?
or under windows?
Won't be able to try this for a while, unfortunately...
Moritz
Again, in spearfish:
$ g.mlist pattern=r*
railroads
roads
rstrct.areas
rushmore
$ g.rename vect=roads,ROADS
Rename vector <roads> to <ROADS>
$ g.mlist -r pattern='^[R|r]'
railroads
roads
rstrct.areas
rushmore
Similarly, with regions:
$ g.list region
region definition files available in mapset <PERMANENT>:
9961 county previous_zoom subregion.NW tributary
$ g.rename region=county,COUNTY
Rename region definition <county> to <COUNTY>
$ g.list region
~ Eric.
It's in manage:
Moritz
Just to make myself clear: it works with the patch of commenting out the above line (and so I assume would work when using strcmp).
Moritz
>>>>> It's in manage:
>>>>> Moritz
Vector map names may be used as SQL column names, which aren't case
sensitive.
railroads
roads
rstrct.areas
rushmore
railroads
roads
rstrct.areas
rushmore
I meant: what happens if you remove the G_strcasecmp() check (or
replace it with strcmp()), then try it.
The problem is that the renaming code (both the generic code in
general/manage/lib/do_rename.c and the vector-specific code in
lib/vector/Vlib/map.c) deletes the destination before renaming the
source. If the source and destination are aliases for the same file
(or database table), then deleting the destination will delete the
source.
