[GRASS-dev] [grass-code R][382] v.colors wish
code R item #382, was opened at 2007-04-25 22:35
Status: Open
Priority: 3
Submitted By: Markus Neteler (markusn)
Assigned to: Nobody (None)
Summary: v.colors wish
Issue status: None
GRASS component: vector
Operating system: all
Operating system version:
Initial Comment:
A v.colors module (script?) is desired which helps to easily colorize
vector maps.
v.colors vectormap column=name color=rulesfile
where
- column defines the column to use for colorization
- color defines a file to the list of attribute-color matches
The principal steps will be:
1. v.db.addcol vectormap col="GRASSRGB varchar(11)"
2. read color definition in the style
     attribute1 color1
     attribute2 color2
     with
       - attributeX be existing attribute in specified column
       - colorX be color name (from X11 color list?) or RGB pattern
3. if needed, translate color names to RRR:GGG:BBB values
4. update attribute table column GRASSRGB
   loop over all lines in rulesfile, doing
      v.db.update vectormap col=GRASSRGB val="RRR:GGG:BBB" where="column=attributeX"
Maybe rather easy to do, some scripting...
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=188&aid=382&group_id=21
[cc from the wish tracker]
vector maps.
where
     attribute1 color1
     attribute2 color2
     with
Date: 2007-05-03 18:31
Sender: Hamish
It is hard to do (efficiently) inside a script alone, as you
need to do some math to interpolate between the rule values for
each data point.
Suggestion: r.what.colors could be expanded to include a
colors=/rules= option to query the color for some value= based
on a predefined rules file instead of a raster map? Then you feed
all the values to be queried to r.what.colors via stdin, and get
a nice list of RRR:GGG:BBB to give to v.db.update.
Instead of v.db.update, write the SQL update statements to a $TMP
file (with ";" at each EOL) then use a single call to db.execute input=,
as this will be much much faster. (see v.in.garmin)
Hamish
ps- this would be really cool for "snail trail" plots
for a geolocated time series of vector point data.
(I have a matlab[/octave] script somewhere that does this
interpolation already, for this same purpose)
