[GRASS-dev] [grass-code R][541] r.series method=max_raster should produce CELL
grass-dev@lists.osgeo.org wrote:
code R item #541, was opened at 2007-11-28 16:37
Status: Open
Priority: 3
Submitted By: Harri Kiiskinen (harrikoo)
Assigned to: Nobody (None)
Summary: r.series method=max_raster should produce CELL
Issue status: None
GRASS component: raster
Operating system: all
Operating system version:
Initial Comment:
It would be quite logical if the r.series with method=max_raster
would produce a CELL instead of DCELL - the data is integers showing
the position of the map in the input= parameter, after all.
The issue applies to the count, min_raster, max_raster and diversity
methods.
I'll commit a fix shortly.
