[GRASS-dev] [grass-code R][562] add support for libedit substitute for readline/history
grass-dev@lists.osgeo.org wrote:
code R item #562, was opened at 2007-12-08 23:38
Status: Open
Priority: 2
Submitted By: William Kyngesburye (kyngchaos)
Assigned to: Nobody (None)
Summary: add support for libedit substitute for readline/history
Issue status: None
GRASS component: GRASS wide
Operating system: MacOS X
Operating system version:
Initial Comment:
libedit is included in OSX, so is more convenient. There is a symlink
to libreadline, but none for libhistory, so the check for readline
support in configure fails.
To be honest, I don't see any point in having the readline support in
the first place. If the expression is complex enough to warrant the
use of readline, you should probably enter it into a text file using
your preferred text editor then use e.g. "r.mapcalc < myscript".
