I am trying to compile grass on a fresh mac (yosemite) and the configure fails with
checking for gdal-config… /Library/Frameworks/GDAL.Framework/Versions/1.11/Programs/gdal-config
configure: error: *** Unable to locate GDAL library.
and this is the configure log:
configure:6036: checking whether to use GDAL
configure:6054: checking for gdal-config
configure:6116: gcc -o conftest -g -O2 -arch i386 -arch x86_64 -I/Library/Frameworks/GDAL.framework/Versions/1.11/Headers -arch i386 -arch x86_64 conftest.c -framework GDAL 1>&5
configure:6112:1: warning: ignoring return value of function declared with warn_unused_result attribute [-Wunused-result]
GDALOpen(“foo”, GA_ReadOnly);
1 warning generated.
ld: framework not found GDAL
clang: error: linker command failed with exit code 1 (use -v to see invocation)
configure: failed program was:
#line 6109 “configure”
#include “confdefs.h”
#include <gdal.h>
int main() {
; return 0; }
configure:6132: gcc -o conftest -g -O2 -arch i386 -arch x86_64 -I/Library/Frameworks/GDAL.framework/Versions/1.11/Headers -arch i386 -arch x86_64 conftest.c -framework GDAL 1>&5
configure:6128:1: warning: ignoring return value of function declared with warn_unused_result attribute [-Wunused-result]
#line 6125 “configure”
#include <gdal.h>
int main() {
; return 0; }
I installed the GDAL framework from Michael’s page and then from William’s too. Nothing really helped.
Any idea? I was able to compile grass couple of months ago without problem on a different computer so I don’t know why it doesn’t work now.
Anna
