Hi Tom,
See below
On 7/27/07 5:01 AM, "Thomas Adams" <Thomas.Adams@noaa.gov> wrote:
Michael,
Thanks for your feedback. I understand how the GRASS GUI is set-up — as
you explain it. I suppose my problem is one of not wanting to break the
current GUI, to avoid problems when new upgrades are released, yet
simplify the user's interaction with the GRASS GUI for the purpose of
using the tools I have in mind. Some of this, I understand, comes down
to a design decision on my part.
Yes. What we have now is a general GUI that attempts to make all GRASS
functions available to the user. However, it is simpler than most people
imagine to craft a custom one for a specific target audience.
I do have a broader question at fits in
with what I am asking about, but also affects others who may have
similar needs, namely:
Should there be some facility within the GRASS GUI that allows people
such as myself to generate some GUI tool that can simply be "dropped"
into GRASS and appear in some consistent way in the main GRASS GUI? The
main GRASS menu bar *may*, for instance, have a new 'Other' or 'Add-on'
or 'Custom' or 'Tools' or whatever menu item to go with the existing
ones ('Raster', 'Vector', 'Imagery', 'Volumes', etc.). Or rather than a
main menu bar item, there could be an icon selection button, for
instance. So that, if someone like myself were to add some new GUI
component in the way I previously describe, then the item would appear
under the new menu item. The 'dropping' into GRASS may consist of some
standard subdirectory in the GRASS build where a subdirectory would be
created by me or others (for each of their 'projects'), where the coding
and some naming convention, etc. would be expected to meet certain
guidelines in order for it to appear in the GRASS GUI.
In this way, there would be both straight-forward programming standards
and easy user access to the new tool without breaking the interface when
new GRASS GUI builds came along. Just a thought…
This is actually 2 questions. For the main one, there are a couple attempts
in progress to do exactly what you describe. These are Benjamin Ducke's GEM
(GRASS Extension Manager) and William Kyngesbury's GRASS modbuild. There
have been some discussions about merging these 2 efforts. From an observer's
perspective watching discussions on the dev list, there seem to be 2 issues
that need to be resolved: 1) where to put any custom modules given that the
'best' place varies by OS; and 2) how to automatically embed custom module
commands into the GUI menu. There is progress being made on both fronts. If
you have interest in this, help is needed to move this forward.
The second, implied question, may be more helpful to your immediate needs.
Both for TclTk and wxPython, the actual interface files are simply ASCII
text scripts. So you can modify them to your heart's content without
compiling. This means that you can (as I've done) engage in a lot of trial
and error experimentation quickly: change a script, quit and restart the
interface (i.e., with gis.m for TclTk or wxgrass for wxPython), watch it
crash, do it again.
If you have a custom interface for GRASS, you can simply drop it into the
current GUI folder, make a new folder and change the target of the calling
script (gis.m or wxgrass), or make a new calling script (e.g., mygui) that
starts your custom app.
I hope this encourages you to try out some of these suggestions.
Michael
Michael Barton wrote:
It is relatively straightforward to create a custom application with GRASS
because all (or very nearly all) GRASS functions can be run as a series of
ASCII commands with arguments and switches.
In essence, this is what the current TclTk GUI and development wxPython GUI
do--execute a series of GRASS commands.
One easy thing that you could do to start is simply begin with the current
TclTk scripts and get rid of anything you don't want to show from the menus
(gmmenu.tcl) or toolbars (gism.tcl and mapdisp.tcl).
Michael
On 7/25/07 3:48 PM, "Thomas Adams" <Thomas.Adams@noaa.gov> wrote:
Folks:
Please take a look at this: http://www.erh.noaa.gov/er/ohrfc/fop.html
which was created using ArcGIS 9.x through some customization of the GUI
to make the creation of the graphic a one-step process. Now, this
graphic could easily be created using a script in GRASS (or, presumably,
in ArcGIS), so it's an uninteresting example. But we use the graphic to
depict areas of potential flooding (as indicated by the legend) by
drawing color-filled polygons with text annotations to indicate the
period over which the flooding is likely, as shown here:
http://www.srh.noaa.gov/wgrfc/fop/wgrfcfop.html
for a different region of the U.S. My question is this: how should I
proceed to do this through some customization of the GRASS interface to
"hide" GRASS details using a somewhat simplified GUI tool. I should add,
that the flood risk polygons are exported to a text format file, which
is then transmitted to a national center to generate a National product
like this:
I am also interested in an unrelated 'custom applcation' that would
essentially combine a series of GRASS analyses into single step
processes utilizing the GRASS GUI to initiate the analyses and set some
parameters ‹ for various hydrologic analyses, including:
(1) identification of snow elevation zones (disconnected regions within
a watershed, above a certain elevation)
(2) basin boundary delineation for a set of watershed outlets (utilizing
r.water.outlet, etc.)
(3) model parameter estimation
I think most of this could be done as GRASS add-ons; would this be the
way to go, or would embellishing the GRASS Tcl/Tk interface be necessary
(something I would rather NOT do for several reasons).
Thanks for any and all feedback!
Tom
Director of Graduate Studies
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
phone: 480-965-6213
fax: 480-965-7671
