OK. Figured it out. But it needs to be fixed somewhere in the make systems I
think.
In both my previous compile (of a few weeks ago) and the one I tried last
night and today, a copy of wish8.4 is put into the $GISBASE/bin folder.
In my older version (which worked fine), apparently this is launched when
the GUI system is launched.
In the new version, it tries to launch a symlink named "wish" instead of the
embedded wish8.4. There is no such symlink and it tries to run another
symlink on my system that is NOT linked to the correct version of TclTk
(I'll fix that locally, but it should not affect GRASS).
When I created a symlink named "wish" for the embedded wish8.4 all works
well.
So what has changed? Something is calling wish instead of wish8.4, but I
don't know what.
Michael
On 11/17/07 9:24 AM, "William Kyngesburye" <woklist@kyngchaos.com> wrote:
On Nov 17, 2007, at 9:41 AM, Michael Barton wrote:
Here is the error.
/Applications/Grass/GRASS-6.3.app/Contents/MacOS/scripts/gis.m: line
17:
/Applications/Grass/GRASS-6.3.app/Contents/MacOS/bin/wish: No such
file or
directory
17:
exec: /Applications/Grass/GRASS-6.3.app/Contents/MacOS/bin/wish:
cannot
execute: No such file or directory
When I try to run wish, this is what I get
wish
dyld: Library not loaded: /usr/local/X11R7/lib/libX11.6.dylib
Referenced from: /usr/local/lib/libtk8.4.dylib
Reason: image not found
Trace/BPT trap
Oh, that's bizarre. Nothing to do with Leopard, though. Things to
check:
- Is there a wish, or any tcltk libraries, in the newly-installed
GRASS app package?
- if not, were there any errors in the make (not install) stage? try
make inside the macosx folder.
- where is your tcltk installed (from those many months ago)? /usr/
local/tcltk, as in my instructions? And is this what you configured
GRASS with? (just checking)
- is there really a /usr/local/bin/wish and /usr/local/lib/libtcl and
libtk? Sounds like you may have installed some software that
installed another copy of tcltk (which is broken because it's looking
for /usr/local/X11R7).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
