[GRASS-dev] GRASS digitizing; splitting lines does not update the cat!
Hi devs,
while working with a very long digitized coastline I encountered the
following problem.
I split the line into pieces in order to give different attributes to
different line segments.
But when I split the line, the cat stays identical. So whenever I
change an attribute of one segment, it gets changed on all other
segments too (because it has the same cat).
This is because no new attribute-entry will be created when a line is
split and the cat stays identical.
Would this be a big deal to change this? Where is the right place to
look at?
My needed behaviour would be that when splitting a line, the
attribute-entry gets copied, the new resulting segment gets a new cat
linked to the copied entry. The left-of-new-point-segment stays old, the
right-of-new-point-segment gets the new cat linked to the new cat.
What do other think? Is this a convnient usecase?
Could this be done with GRASS/QGIS right now?
Thanks for your comments.
Best regards
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
following problem.
look at?
The functionlityyou are describing would be very usefull for me as an
option. But the current behaviour should also be still available - it
has it's own uses.
Currently you can remove the old cat and add a new one, then fill the
attribute table again. This becomes a problem, when you have, say, 100
attributes but only wan't one to be different :(.
AFAIK same as above. I would love to see such a functionality in QGIS
Grass edit tool, too.
Maciek
Hello Maciej,
On Mon, 25 Sep 2006 17:22:54 +0200 Maciej Sieczka <tutey@o2.pl> wrote:
> following problem.
> to different line segments.
> is split and the cat stays identical.
> look at?
> cat linked to the copied entry. The left-of-new-point-segment stays
> old, the right-of-new-point-segment gets the new cat linked to the
> new cat.
has it's own uses.
Yes, you are right.
Exactly.
If someone could point to the place in the sources where to start I
would like to try what I can do.
AFAIK the following steps need to be done.
1) finding the funtion, which does the spliting
2) get maximal category number from db
3) select values from database
4) assign new cat to new line-part
4) store copy of the values to database table with new category number
Yes, thats the place I like to have it too!!
Best regards
  Stephan
It should be probably a new tool with a new button in toolbox.
Radim
On 9/26/06, Stephan Holl <holl@gdf-hannover.de> wrote:
Hello Maciej,
> > following problem.
> > look at?
> > new cat.
> has it's own uses.
Yes, you are right.
Exactly.
Best regards
        Stephan
grass-dev mailing list
grass-dev@grass.itc.it
Hello Radim,
On Tue, 26 Sep 2006 16:37:29 +0200 "Radim Blazek"
sounds promissing! Can you forsee if this finds some priority on a
developers (perhaps your) todo-list?
Am I right, that this needs to be implemented in GRASS first, befor we
can make use of it in QGIS or is this independent from GRASS and could
be implemented only in QGIS digitize tool?
Best regards
  Stephan
> Hello Maciej,
> wrote:
> > > encountered the following problem.
> > > attributes to different line segments.
> > > I change an attribute of one segment, it gets changed on all
> > > other segments too (because it has the same cat).
> > > line is split and the cat stays identical.
> > > place to look at?
> > > new cat linked to the copied entry. The
> > > cat.
> > as an option. But the current behaviour should also be still
> > available - it has it's own uses.
> Yes, you are right.
> > the attribute table again. This becomes a problem, when you have,
> > say, 100 attributes but only wan't one to be different :(.
> Exactly.
> number
> > QGIS Grass edit tool, too.
> Best regards
> Stephan
> sensing Hannover Office - Mengendamm 16d -
> D-30177 Hannover Internet: www.gdf-hannover.de - Email:
> holl@gdf-hannover.de Phone : ++49-(0)511.39088507 -
Hello Radim,
Sorry, forget it. It should be an option on the first tab
(currently cat only). The options should be shown/hidden according
to the selected tool. Another option could be snapping mode
(nearest, nearest vertex,...).
Yes (I foresee), no (priority).
No.
Yes.
Radim
Best regards
        Stephan
> > Hello Maciej,
> > > > place to look at?
> > > > cat.
> > Yes, you are right.
> > Exactly.
> > number
> > Best regards
> > Stephan
> > _______________________________________________
Hello Radim,
On Wed, 27 Sep 2006 10:27:42 +0200 "Radim Blazek"
> Hello Radim,
> we can make use of it in QGIS
No.
Yes.
Thanks!
Stephan
