[GRASS-dev] [grass-doc I][406] d.rast.edit: new script needs docs ported from old C module
doc I item #406, was opened at 2007-05-23 18:13
Status: Open
Priority: 3
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: d.rast.edit: new script needs docs ported from old C module
Issue status: None
Doc section: display
GRASS version: CVS HEAD
Doc timestamp (YYMMDD):
Initial Comment:
there's a fancy new Tcl d.rast.edit module in CVS, but its scripts/d.rast.edit/description.html file is mostly empty.
The relevant bits need to be "ported" from the old C version, in display/d.rast.edit/description.html. Lots of that will be irrelevant, so a straight copy is no good.
e.g. explain what the aspect option is used for.
thanks,
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=406&group_id=21
