[GRASS-dev] [grass-doc I][559] man r.in.gdal
grass-dev@lists.osgeo.org wrote:
doc I item #559, was opened at 2007-12-07 17:38
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: man r.in.gdal
Issue status: None
Doc section: None
GRASS version: None
Doc timestamp (YYMMDD):
Initial Comment:
When I do man r.in.gdal within the (GRASS-)terminal, the "GDAL
supported raster formats" section is not easily readable... (does not
look like a table).
Is it possible to force it to to look like a table?
Although g.html2man attempts to convert tables, it clearly doesn't
work. Consequently, raster/r.in.gdal/description.html should be
changed to use pre-formatted text instead of an HTML table.
