[GRASS-dev] GRASS Docker container - new website ?
I just found the docker images, and am happy, that they are there!
But I am have three questions:
There is limited info on how they can be used on https://hub.docker.com/r/mundialis/grass-py3-pdal but there is no mention of the GUI (I assume it is not working?) or examples on how the image can be used. It would eb useful, if some more info could be provided by somebody who uses / knows these images. It would be useful, to include a link to the documentations itself in the new website.
The second questions concerns the R integration - it sounds intriguing, to consider that R interfaces with the GRASS docker container. Is this possible? Has somebody tried it?
The third question concerns AddOns - are they installed in the container, or outside?
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Orcid ID: 0000-0002-7490-0066
Department of Evolutionary Biology and Environmental Studies
University of Zürich
Office Y34-J-74
Winterthurerstrasse 190
8075 Zürich
Switzerland
Office: +41 (0)44 635 47 64
Cell: +41 (0)78 630 66 57
email: Rainer.Krug@uzh.ch
    Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
Hi Rainer,
There is more info here but dockerhub isn't showing it...
An attempt with GUI is here:
https://hub.docker.com/r/neteler/docker-alpine-grass-gis-gui
based on https://github.com/OSGeo/grass/blob/master/docker/alpine/Dockerfile_alpine_wxgui
Agreed... it is all due to lack of time but writing documentation
could be done by "anyone".
I haven't but others likely yes.
I'd suggest a multi-stage docker build approach to "blend" the
different images together.
We do that inside while building it (in this case "actinia" which uses
above docker images as the basis) with a convenient CSV file listing
the addons and their respective repos:
see
https://github.com/mundialis/actinia_core/blob/master/docker/actinia-core/Dockerfile#L73
HTH,
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Thanks Markus for the info.
I have no need for GRASS at the moment, so I likely won’t look into this, but it sounded intriguing. My thought was to run R normal, and have GRASS in a docker container.
Will think about it, when I have time.
Rainer
On 3 Jul 2020, at 16:15, Markus Neteler <neteler@osgeo.org> wrote:
Hi Rainer,
There is more info here but dockerhub isn’t showing it…
Agreed… it is all due to lack of time but writing documentation
could be done by “anyone”.
I haven’t but others likely yes.
I’d suggest a multi-stage docker build approach to “blend” the
We do that inside while building it (in this case “actinia” which uses
see
HTH,
Markus Neteler, PhD
Office Y34-J-74
8075 Zürich
Switzerland
Rainer@krugs.de
Skype: RMkrug
PGP: 0x0F52F982
