Hello,
Since I'm using GRASS(6.4.0RC6) concurrently with other software suites
for image pre-processing, I'd like to propose an enhancement that will
encourage some interesting applications of GRASS GIS combined with other
tools that setup a working environment like grass.
At the moment I'm using system's LD_LIBRARY_PATH for adding specific
extra libs, and GRASS_ADDON_PATH to add extra scripts and executables I
want to use within GRASS GIS.
Especially for the case of some specific libraries, these are mostly
useful within the data analysis session -- and are not useful as
system-wide libraries, so I ended up with a custom Init.sh script that
set them for me within the GRASS session.
To enable a generic concurrent use of other software tools within the
GRASS session, maybe we can enable Init.sh to read two new environmental
variables:
GRASS_EXTRA_PATH and GRASS_EXTRA_LIB,
to be set by the user before the session, and then to be added to the
PATH and GRASS_LD_LIBRARY_PATH by the Init.sh.
Maybe there is a more smart or more safe way to do it, this is just an
idea from which to start on.
Alessandro
Alessandro Frigeri, PhD
University of Perugia, Italy
Note that you can use ~/.grass.bashrc for commands which are to be run
at the beginning of a GRASS session.
Hi Glynn,
The use of ~/.grass.bashrc is the perfect solution to my problem.
Thanks for the hint!
Alessandro
2010/4/9 Glynn Clements <glynn@gclements.plus.com>:
