[GRASS-dev] grass fails to detect wxpython version
Hi All,
for some reason i need to switch to python 2.7 on mac osx
i'm using a custom build python2.7 (i386 + x86_64)
it is my default python version.
epy:~ epy$ which python
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
I'm using a snapshot buld for wx python2.9 (build with cocoa for python2.7)
it is available there :
http://wxpython.wxcommunity.com/preview/20101001/
http://wxpython.wxcommunity.com/preview/20101001/wxPython2.9-osx-2.9.1.1.b20101001-cocoa-py2.7.dmg
tring to run wx-config, i have :
/usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config --version-full
2.9.1.1
i'm building grass6_devel using as wx configure, this line :
--with-wxwidgets=/usr/local/lib/wxPython-2.9.1.1.b20101001/bin/wx-config
the build ends without errors but tring to run grass i have :
GRASS 6.5.svn (<UNKNOWN>):~ > g.gui
Launching 'wxpython' GUI in the background, please wait ...
ERROR: wxGUI requires wxPython >= 2.8.1.1. Requested version of wxPython not found.
whay it tel me a version < 2.8 ?
my new wc-config is not in the path .. can be this the reason ? i suppose configure should handle the path i issued to the wxwidgets options.
have you any clue on what's wrong ?
thanks,
Massimo.
