[GRASS-dev] [GRASS GIS] #100: v.surf.rst also crashes on Mac OS X
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: blocker | Milestone: 6.3.0
Component: default | Version: unspecified
Keywords: |
OK. v.surf.rst also crashes before it even starts. So that only
interpolation routines that works for me is v.surf.idw and one routine for
r.resamp.interp.
FWIW, I'm running this on a version of GRASS from the SVN trunk compiled
on 1 March 2008.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/100&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by hamish):
how big is your region?
since all these things fail maybe it is some common problem?
this is all on OSX 10.5?
exact command lines and error messages, etc?
g.gisenv set="DEBUG=5" ?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:1&gt;
Comment (by cmbarton):
This is happening with Spearfish and with the new NC dataset. I've simply
set my region to match the elevation DEM. In the NC dataset, I think this
is a little over 2million cells. This is not extraordinarily large and it
IS the demo set for GRASS.
It is with 10.4 AND with 10.5 for everything except r.random. This is only
with 10.5.
I'm also finding that r.resamp.interp says it makes maps, but it does not.
With the neighbors algorithm, it makes a map that is exactly the raster
points that are input. That is, there is no interpolation. For bilinear
and bicubic, it makes NAN maps. I've checked this with r.info. I'll give
examples below. Note that the output of the nearest routine produces only
500 points (see r.univar results)--the same number I used as points for
interpolation. Also note that I just updated from the SVN trunk, did a
make distclean, and compiled fresh this afternoon.
Michael
---- output from running r.resamp.interp -----
GRASS 6.3.svn (nc_spm_07):~ > r.info elev500bilinear
  | Layer: elev500bilinear Date: Tue Mar 18 21:12:23 2008
  | Mapset: spatialtech2008 Login of Creator: cmbarton
  | DataBase: /Users/Shared/grassdata
  | Title: Resample by bilinear interpolation ( elev500bilinear )
  | Timestamp: none
  | Type of Map: raster Number of Categories: 255
  | Data Type: DCELL
  | Rows: 1350
  | Columns: 1500
  | Total Cells: 2025000
  | Projection: Lambert Conformal Conic
  | N: 228500 S: 215000 Res: 10
  | E: 645000 W: 630000 Res: 10
  | Range of data: min = nan max = nan
  | Data Source:
  | elev_pts500@spatialtech2008
  | Source map NS res: 10 EW res: 10
  | Data Description:
  | generated by r.resamp.interp
  | Comments:
  | r.resamp.interp input="elev_pts500@spatialtech2008"
output="elev500b\ |
  | ilinear" method="bilinear"
GRASS 6.3.svn (nc_spm_07):~ > r.info elev500nearest
  | Layer: elev500nearest Date: Tue Mar 18 21:12:59 2008
  | Title: Resample by nearest interpolation ( elev500nearest )
  | Timestamp: none
  | Data Type: DCELL
  | Rows: 1350
  | Columns: 1500
  | Range of data: min = 57.820839 max = 154.312943
  | Data Source:
  | Data Description:
  | Comments:
output="elev500n\ |
  | earest" method="nearest"
GRASS 6.3.svn (nc_spm_07):~ > r.univar elev500nearest
  100%
total null and non-null cells: 2025000
total null cells: 2024500
Of the non-null cells:
n: 500
minimum: 57.8208
maximum: 154.313
range: 96.4921
mean: 111.107
mean of absolute values: 111.107
standard deviation: 21.0507
variance: 443.131
variation coefficient: 18.9463 %
sum: 55553.4484596252
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:2&gt;
Comment (by glynn):
Replying to [comment:2 cmbarton]:
not. With the neighbors algorithm, it makes a map that is exactly the
raster points that are input. That is, there is no interpolation. For
bilinear and bicubic, it makes NAN maps.
You are misunderstanding what r.resamp.interp does. It does not "fill"
null areas (like e.g. r.surf.idw or r.fillnulls). It resamples a map,
calculating cell values by interpolating between the neighbouring cells,
all of which must be non-null in order to get a non-null result.
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:3&gt;
At this point we should improve the documentation:
Current:
"<EM>r.resamp.interp</EM> fills a grid cell (raster) matrix with
interpolated values
generated from a set of input layer data points."
New:
[I have changed the subject]
how about:
"<EM>r.resamp.interp</EM> resamples or re-interpolates the given raster map to the current resolution
(or resolution given by the current region setting)?
Helena
Current:
interpolated values
New:
grass-dev mailing list
Markus:
Current:
interpolated values generated from a set of input layer data points."
New:
How about this:
"r.resamp.interp resamples an input raster map by interpolating between the neighboring
cells via one of nearest neighbor, bilinear, or cubic resampling algorithms. All cells
present in the neighborhood of the input raster cell must be non-null to generate a non-null
cell in the output raster map."
~ Eric.
Markus:
>Current:
>New:
How about this:
Submitted in slightly modified form to r.resamp.interp/description.html .
#100: v.surf.rst crashes on Mac OS X
Resolution: | Keywords: osx
Changes (by hamish):
  * keywords: => osx
  * summary: v.surf.rst also crashes on Mac OS X => v.surf.rst crashes on
              Mac OS X
Comment:
I have just tested v.surf.rst and r.random from William's 6.3.0rc4
binaries on OSX 10.4, and both worked fine.
#spearfish
g.region -d
v.surf.rst in=archsites elev=arch_surf zcol=cat
r.random in=elevation.dem rast=rand_elev.1000 n=1000
(r.random was expected to work here, it was only failing with OSX 10.5)
is any one else see a problem with v.surf.rst on OSX?
worksforme,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:4&gt;
I hope to finally get GRASS recompiled on my MacBook this week. This
requires reverting to the previous version of shapelib (if this has not yet
been done in the SVN), but I think that should do it.
I'll test again. Hopefully there will be no problem for me either.
Michael
  * keywords: => osx
              Mac OS X
Comment:
#spearfish
g.region -d
worksforme,
Hamish
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
  Priority: critical | Milestone: 6.3.0
Component: default | Version: svn-trunk
Changes (by neteler):
  * priority: blocker => critical
  * version: unspecified => svn-trunk
Comment:
priority downgraded since it works fro Hamish.
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:5&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: osx
  * status: new => closed
  * resolution: => worksforme
Comment:
Michael reported on grass-dev that it now works for him. no one else has
reported problems.
shrug. closing bug.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:6&gt;
