GDAL
March 14, 2010, 6:35am
1
#1000: v.category option=del doesn't delete multiple cats per object
Reporter: needelsd | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.category v.to.points v.clean delete replace cats | Platform: Unspecified
Cpu: Unspecified |
The manual for for v.category option=del states that it will "delete all
categories of given layer". However, only one cat per object is deleted
for objects with multiple cats (listed separated by a "/").
Here is a Spearfish example that starts with a line vector with multiple
segments, generates a point vector from the nodes (in layer 2), removes
the resulting duplicate points, and then attempts to delete the layer 2
cats in order to generate new cats with sequential values.
# Extract 5 lines, extract nodes into layer 2
v.edit map=L_1 tool=create --o
v.edit map=L_1 tool=copy ids=17,424-426,496 bgmap=roads
v.to.points -n input=L_1 output=P_1_raw
# Remove duplicate points (overlapping nodes from adjacent segments)
v.clean input=P_1_raw output=P_1 tool=snap,rmdupl thresh=.1,-1 type=point
--o
# Replace cat values with sequential values
v.category input=P_1 output=P_1_no_cats option=del layer=2 --o
v.category input=P_1_no_cats output=P_1_cats option=add layer=2 --o
# Expected result- layer 2 cat values 1-6
v.category input=P_1_cats option=print layer=2
## cat 1 2 1 2 3 6
# The v.clean tool=rmdupl step results in objects with multiple cats
separated by "/"
v.category P_1 option=print layer=2
## cat 4 9 10/1 5/2 8/3 7/6
# The v.category option=del step only removes the first cat of each pair
v.category input=P_1_no_cats option=print layer=2
## cat 1 2 3 6
Ticket URL: <http://trac.osgeo.org/grass/ticket/1000> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
March 14, 2010, 6:41am
2
Resolution: | Keywords: v.category v.to.points v.clean delete replace cats
Platform: Unspecified | Cpu: Unspecified
Comment (by needelsd):
I am running William Kyngesburye's 6.4RC5-3 on Mac OS X Leopard.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1000#comment:1> ;
GDAL
March 14, 2010, 1:42pm
3
Comment (by martinl):
Replying to [ticket:1000 needelsd]:
Please use pre-formatted text otherwise it's not readable.
--o
## cat 1 2 1 2 3 6
separated by "/"
## cat 1 2 3 6
Ticket URL: <http://trac.osgeo.org/grass/ticket/1000#comment:2> ;
GDAL
March 14, 2010, 6:53pm
4
Thanks for cleaning up my mess (newbie error). Note to self: the Preview
button is there for a reason.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1000#comment:3> ;
GDAL
August 20, 2012, 2:16pm
5
Reporter: needelsd | Owner: grass-dev@…
Type: defect | Status: closed
Resolution: fixed | Keywords: v.category v.to.points v.clean delete replace cats
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
Fixed in all branches (r52773, 5, 6).
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1000#comment:4> ;
