#1001: Add option to replace (instead of just add) cats with v.category
Reporter: needelsd | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: 6.4.0 RCs
Keywords: v.category add del replace cats | Platform: Unspecified
Cpu: Unspecified |
Add an option to v.category option=replace that overwrites the cat values
in a vector instead of only adding a cat to objects that do not already
have a cat.
Resolution: | Keywords: v.category add del replace cats
Platform: Unspecified | Cpu: Unspecified
Old description:
have a cat.
Personally, I would also appreciate a flag [-r]?? or other mechanism to
overwrite cats in the original vector (allow output=input).
New description:
have a cat.
Comment (by needelsd):
> aka v.edit?
As far as I can tell the v.edit tool=catadd does not replace cats. It
appears to append the same one or more cats designated by cats= to every
feature selected by ids=, but without incrementing the cat value.
Is there a way to tell v.edit to add sequential cat numbers or to replace
an existing cat with a new one?
But v.edit does make changes to the original file. Also, the tool=catdel
ids=1-9999 cats=1-9999 does delete all multiple cats associated with
individual selected vector features.
