#1005: db.out.ogr together with g.parser doesn't play nicely with non-lati
characters containing DSN
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows Vista
Cpu: x86-32 |
Select any table and set DNS to contain non-latin characters. I added -x,
also echo before g.parser and before v.out.ogr.
Output when running from CLI:
GRASS 6.4.0svn (latvija3)> db.out.ogr input=autoceli
dsn="C:\Users\Maris\Documen
ts\Šaursliežu dzelzceļš\šaurā datubāze"
+ '[' -z 'C:/Program Files/GRASS-64-SVN' ']'
+ '[' input=autoceli '!=' @ARGS_PARSED@ ']'
+ echo 'Calling g.parser with following args: C:/Program Files/GRASS-64-
SVN/scri
pts/db.out.ogr input=autoceli' 'dsn=C:\Users\Maris\Documents\Šaursliežu
dzelzceļ
š\šaurā datubāze'
SVN/scripts/db.o
ut.ogr input=autoceli dsn=C:\Users\Maris\Documents\Šaursliežu
dzelzceļš\šaurā da
tubāze
+ exec g.parser 'C:/Program Files/GRASS-64-SVN/scripts/db.out.ogr'
input=autocel
i 'dsn=C:\Users\Maris\Documents\Šaursliežu dzelzceļš\šaurā datubāze'
DSN value before calling v.out.ogr: C:\Users\Maris\Documents\¾aurslieŲu
dzelzceė
Õ\Õaur? datub?ze
ERROR 1: Failed to create directory C:\Users\Maris\Documents\Šaursliežu
dzelzceļ
š\šaurā datubāze
for shapefile datastore.
KŽ█DA:Unable to open OGR data source 'C:\Users\Maris\Documents\Šaursliežu
ts\Šaursliežu dzelzceļš\šaurā datubāze" format=CSV
SVN/scri
dzelzceļ
š\šaurā datubāze' format=CSV
SVN/scripts/db.o
dzelzceļš\šaurā da
tubāze format=CSV
input=autocel
format=CSV
dzelzceė
Õ\Õaur? datub?ze
Atvainojiet, <datubāze> ir nedrŅgs parametrs
Output when running from wxgui:
(Sun Mar 14 18:33:22 2010)
db.out.ogr input=autoceli dsn=C:\Users\Maris\Documents\Šaursliežu
dzelzceļš\šaurā datubāze format=CSV
Files/GRASS-64-SVN/scripts/db.out.ogr input=autoceli'
Files/GRASS-64-SVN/scripts/db.out.ogr' input=autoceli
format=CSV
dzelzceėÕ\Õaur datubze
Atvainojiet, <datubze> ir nedrīgs parametrs
(Sun Mar 14 18:33:23 2010) Command finished (0 sec)
(Sun Mar 14 18:33:40 2010)
datubāze'
datubāze'
C:\Users\Maris\Documents\¾aurslieŲu dzelzceėÕ\Õaur datubze
ERROR: Unable to open OGR data source 'C:\Users\Maris\Documents\¾aurslieŲu
dzelzceėÕ\Õaur datubze'
(Sun Mar 14 18:33:40 2010) Command finished (0 sec)
No problems observed when running on Linux with UTF-8 locale. Also there
are no problems when pointing v.out.ogr (from wxgui) to DSN that contains
WinGRASS-6.4.SVN-r41428-1 running Windows Vista with region set to Latvia.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1005>
