[GRASS-dev] [GRASS GIS] #1009: r.param.scale outputs wrong values in last (bottom) row
Reporter: marisn | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
When feature map is created, it contains also data in last (most bottom
one) row, still it's impossible to gather data for that row, as
r.param.scale uses sliding window method and thus last line would have to
deal with NULLs coming from outside from computational region. Current
r.param.scale output more looks like last line is repeated twice instead
of setting it to be NULL.
Test procedure:
g.region rast=elevation.dem@PERMANENT
r.param.scale input=elevation.dem@PERMANENT output=features param=feature
Ticket URL: <http://trac.osgeo.org/grass/ticket/1009&gt;
